Don't sweat it, it is normal. The rears are used a small percentage relative to the fronts. It is only surface corrosion which will disappear during usage.I drove around pretty aggressively for an hour. It's fine on the front, but not all gone on the rears. it is significantly better, but not all gone. I guess I just have to do some more spirited driving
Yeah, I think that made it gunk up and harder to scrape off. Its getting better, though. No stinky brake smell hahano, just do light driving. slower/cold stops will scrape this stuff off. if you get your pads all hot, its just going to embed into the rust.
It will not increase braking performance unless the brakes are properly "bedded" afterwards.You can also take your Brakes apart and scuff the rust off the rotors and pads with fine sandpaper. That also helps to break the glaze on the rotors which Happens over time. It will increase braking performance.
Never use this crap. When I used it, it stained the fcuk out of my calipers. Good thing I'm getting them painted.Try this cleaner, it will help but you still have to drive around
I've had the opposite effect, wet wheel, spray, use soft brush and rinse, don't let it dry in the wheels and it actually cleans some of the rust out, maybe I've been lucky...Never use this crap. When I used it, it stained the fcuk out of my calipers. Good thing I'm getting them painted.
