1 - 9 of 9 Posts
Hello guys,
I am writing to the Lotus Community in hopes of getting some feedback on maintenance.
Currently, the car has 40k miles and I am planning on taking a road trip from Miami --> Philly
In order to have a stress free trip, I'd like some advice and guidance as to how to keep my car running well.
1) At low speeds, I experience a sort of clanking sound from the imperfections on the road. To me, it seems like new either bushings or ball joints would be needed, is this a fair evaluation?
2) Toe links- How can I check on these, and is this something that should be replaced assuming the car was never tracked ?
Also, if anyone would like to recommend some cool places to visit along the way to PA, possibly some notable roads a car enthusiast would love, please feel free to comment!
Feel free to post links to parts that you feel would improve ride quality too!!
Thanks in advance to anyone who leaves their feedback!
Regards,
On my 2009 Elise I have about 168,000 miles in 11 years.
After about 100,000 miles I had the OEM shocks replaced
At about 120,000 I had some tie rods and some ball joints replaced.
If you have 40,000 miles I think you are probably OK for some time.
Literally no OEM bushings make it to 120000 miles. They are all walking before then cmon dave...
Ride quality is 300% improved with stiffer shocks. Penske SA or DA if the budget allows, but anything is better then stock.
Check things like the shock mounts being loose, the control arms walking out of the bushings and hitting the frame, and jack up the car and see if you have any play anywhere when you move the tires by hand.
My personal theory on the toe link issue is that the primary cause of failure is that the bolt walks out first, then this leads to failure. Simply keeping an eye on these bolts (and all suspension bolts, for that matter) is sufficient for a street car.
To check them, a simple visual followed by a torque wrench is all you need. For mine, I could visually see that the nut had fallen clean off, and the bolt was holding on purely by a couple new threads it had cut itself into the subframe. This was with an aftermarket brace, too. I'd have to google the torque spec, but I'll leave that to your capable google skills ;)
Yeah the stock bolts get loose, and once they are loose they break right away because they cant hold loads in shear. To fix you can tighten them regularly. Run a larger bolt and tighten it more (what I did) Or run them in double shear, so that when they get loose they might not break right away (they will still break quick though). The actual arms don't fail.
I use Nord-Lock washers for toe links, marked with felt tip pen.
That way i can tell if anything moved.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
2008 Exige S240
As per your question:
"1) At low speeds, I experience a sort of clanking sound from the imperfections on the road. To me, it seems like new either bushings or ball joints would be needed, is this a fair evaluation?"
-The clanking or maybe more aptly described as 'clunking' could be a bad steering rack OR worm or loose anti-roll bar bushings. You can remove the plastic cover inside the wheel well to inspect the anti-roll bar bushings. It's riveted I believe. It is not the wheel well splash shield, rather a small rectangluar-ish piece of ABS.
-Check your front signals too. They may pop out.
Excellent! I really appreciate your guys' feedback on these details.
Thanks GLB for the extensive list of tips as well.
Feeling confident now about what needs to be bought
Regards
1 - 9 of 9 Posts
