1 - 1 of 1 Posts
Based on stickers on the headlamp assemblies (and asking what PC and PPO meant in plastic speak) and hearing some talk about cloudy (ie dirty) lens (insides specifically), I thought this might help out a bit...it was in a pdf document concerning the new C6 Vette..but fully describes the Elise set up including the venting...
The headlamps feature a clear polycarbonate lenses.
Customers may note that when the lamps are on,
light fog or cloudiness may be visible on the lenses.
This is a normal condition caused by out gassing. The
headlamps are also vented, thus some
condensation/moisture may be seen when humidity is
high or there is a change in temperature. The moisture
should burn off after one hour of headlamps being
turned on.
1 - 1 of 1 Posts
