1 - 20 of 27 Posts
Did you maybe google elise camshaft? Jesus.... And 4k is on the very high end.
See last entry.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Just to bring this full circle for the OP, yes, this is a very well documented and known issue. Many users of this community have done hours of research, posted theories on causes and logged their fix/installation experiences here. We would suggest you go to google, search the issue and you'll quick find a ton of information, including cost information (likely). Sorry you had to discover the issue this way - good luck getting it fixed.
2005 Elise LSS Saffron Yellow
Maybe not quite as diplomatic as I might have tried to be (note 'tried'), but a valid point. @Cnm2205, these cars have been in the US for 14 years now. Some have 100,000+ miles on them. This board has been active (initially as EliseTalk) for longer than that. All of the behaviors of a US market Elise are pretty well documented here at this late date.
If your car is doing something, chances are beyond excellent that there are at least two threads about whatever it is, whether it's normal or not, and alternatives for what to do about it.
A weakness of this forum is that we have stickied posts, but no real organization for them. I'd like to see something like the "Book of Knowledge" at CrownVic.net, where really good informational and how-to posts are in one place organized by functional area of the car.
In the meantime, Google is your friend. My standard technique when I need to find out about something is to do a site specific search in Google. Example: "oil cooler" site:lotustalk.com. The top return on this is the very active "what do I do about the fact that my Elise over cools its oil" thread. This behavior is widely believed to be related to the frequency of intake cam wipes on Eliges, as a similar issue has not been observed on 2ZZ-GE engines in other vehicles.
Plural of Lotus is Lotus
I've replaced 2. One with OEM that lasted 7K miles. Went with MonkeyWrench racing intake cam here https://www.monkeywrenchracing.com/product/mwr-cam-1-toyota-2zz-ge-stage-0-intake-only/. Labor cost was 6 hours time. If someone is telling you it takes more time than that, move on to someone else.
In addition, I installed an oil temp and pressure sensor as I believe the issue is caused by oil being too cool when the engine allows you to jump on the high cam. I can confirm that when the water temp gets to 160 (the point at which the engine allows cam 2 engagement), the oil is way too cool.
My water temp/oil temp numbers are as follows:
Cold start and go - ambient temp mid 50s F.
Time----------- Oil Temp
4 Min 14 Sec , 120 degrees F
5 min 27 Sec = 140 degrees F
7 Min 33 Sec = 160 degrees F
9 Min 48 Sec = 180 degrees F This is when I would get on 2nd cam
At 4 minutes 14 seconds, water temp hits 160, which is when the car will LET you engage 2nd cam, however it takes another 5 minutes before the oil is warm enough, in my opinion as I wait for 180 degree oil temp.
Reactions: iana
Lotus Technician
$4k!!! holy crap, that is ridiculous. Where are you located? that job is a 5-6 hour job, plus, cam, rocker arm set, and maybe a valve cover gasket.
Best of luck to you. if you need any advice or help on this, feel free to shoot me a pm.
T.J.
I was told that this was a $1000 repair job. How can it be 4k??
Even $1k is high - this is a great intro job for anyone just starting to work on a car. You don't have to pull the rear clam, and none of the actual work is hard. It is well-documented, and can give you the confidence to work on more projects.
So $1k isn't bad for paying a shop to do it, but most of us would spend more time driving back and forth to a Lotus shop than this repair actually takes.
Discussion Starter · #15 ·
Hi thanks for replying to my post on the ‘05 Elise camshafts. I am located in Massachusetts....I had to bring the lotus to the lotus dealer bc no one around here was willing to “mess with it” do you think it’s an easy fix for a mechanic now that I know what’s wrong with it? Before it needed a diagnosis run on it
It's a Toyota engine -- so any mechanic that can work on a toyota engine should be able to do it.
Don't follow that logic too blindly though - had to help a local owner flush his oil after the Toyota dealer insisted that 5w30 was the correct oil. I stand by my previous statement that this is a great DIY project, and I also am convinced that DIY is the only way to make sure the person working on the car knows anything.
Dealer list on the cam and gasket is over 850 bucks. I could see with a very high rate and generous service time it getting close to 3 grand, but 4 is over the top.
Where in Mass are you?
IT is the right oil for a Toyota.
I doubt that any damage would occur from running 10w-30
Still, point taken.
Care in choosing, and knowing things rather than being led are the best idea
1 - 20 of 27 Posts
