1 - 20 of 1729 Posts
What??, does this work with Fed S2 elise? This looks really nice? plug and play setup??
How much is it?
Sorry for my ignorance
what is a "FED" Elise
The product is on beta test in the UK
It is plug compatible and a direct swap for the original
It works on all S1 and S2 Elise models, S3 to follow.
It is posted here for feedback and comments
further info to follow
not available for sale yet , that would be against forum rules.
but would like any feedback while its in testing
The US models are Toyota not K series. The cluster is not interchangeable.
It is interchangeable
the test car is an S1 the most complex of all variants with direct sensors connected to dash,
Toyota cars are canbus which was covered in the first version
see desktop test operating both LCD and original cluster from the same canbus feed
there is no lag only software damping to soften movements
If this works with the Fed Toyota and the price is good. There are a lot of guys interested in this I believe.
thanks
after UK testing I will send some over for you guys to have a go
technical info tells me they will work but I have not been to the states
to find out for myself
please feel free to suggest mods, constructive criticism always welcome
Addict
2007 Lotus Exige S
Looks great, interested if it will really work in the USA. Can the odometer be changed to reflect actual mileage or how will that part work?
purveyor of lightness
Alec,
Wonderful work - have some questions though...
  1. What is the LCD screen size and what is the footprint for the entire module?
  2. Will it occupy the space taken by the existing analog cluster without modifications to the surrounding shrouds?
  3. Will holding down the stock (trip-reset) illumination button adjust the brightness level?
  4. How do you set the initial mileage?
  5. Is there another button to change gauge selections?
  6. Can you tweak the speedo correction factor to allow for different rear tire sizes?
  7. Folks that know me know that I have to ask "what does it weigh vs. stock?" :)
  • I LOVE the stock bluish/white Stack appearance and it seems that you have the software damping just about perfect!! Kalman filter? :)
  • It was difficult to distinguish the digital Stack representation from the real thing while you were driving!
  • I would LOVE the initial LOTUS startup logo to appear when first switching on ignition... choice or green/yellow or black/silver please :)
Dislikes:
  • The 3d representation of the Elise with the doors/open closing is a bit fussy. Make sure you can disable it... I know if my doors are open! :)
  • I'm not a fan of the burnt orange color scheme... it looks like something is malfunctioning with the uneven illumination IMHO
Wish List:
  • The 2008+ white-on-black layout with dynamic color bands as you approached the rev-limiter (like you do with the "V" needle configuration)
  • The E46 BMW M3 dynamically changes it's redline as the engine warms up. Our ECU already limits the revs so you could match it on the gauges... :drool:
I have never been a digital dash guy EVER but this looks amazing!
Kudos!
Here's something similar I did.. Installed a micro PC with multiple inputs and dash command. Pretty simple. Find a display, mini PC and use obd2 or convert canbus sensors to usb. I just used my stock stereo for the display output.
Discussion Starter #16
the odo starts from zero, but a preset value can be requested if needed to match the original.
...if that was your question.
Discussion Starter #17
Alec,
  1. What is the LCD screen size and what is the footprint for the entire module? ---7 inch screen
  2. Will it occupy the space taken by the existing analog cluster without modifications to the surrounding shrouds?----no mods
  3. Will holding down the stock (trip-reset) illumination button adjust the brightness level?--no but thats a good idea , trip reset is now a multifuction switch, single press changes screens, long press on classic screen resets trip, long press on race screen enters the 3rd settings screen. currently the screen is dimmed when lights are on
    and this brightness is preset in the 3rd settings screen
  4. How do you set the initial mileage? --zero or it can be pre programmed when built . so tell me the number and i will enter it in memeory
  5. Is there another button to change gauge selections?--no its the trip button
  6. Can you tweak the speedo correction factor to allow for different rear tire sizes?--- not yet but I will add that in the settings, nice one
  7. Folks that know me know that I have to ask "what does it weigh vs. stock?" :)---it does weigh more its machined aluminum I will weigh it and compare
  • I would LOVE the initial LOTUS startup logo to appear when first switching on ignition... choice or green/yellow or black/silver please :)---- not sure if I will get in trouble for this with Lotus thats why I left it out of the last version in car
Dislikes:
  • The 3d representation of the Elise with the doors/open closing is a bit fussy. Make sure you can disable it... I know if my doors are open! :) -------very true it was an experiment and then i thought it would get very annoying seeing it every day, so I took it out
---ye its the cameras fault its more red
Wish List:
  • The 2008+ white-on-black layout with dynamic color bands as you approached the rev-limiter (like you do with the "V" needle configuration)---nice i do have those graphics in creation, but not with the dynamic redline
  • The E46 BMW M3 dynamically changes it's redline as the engine warms up. Our ECU already limits the revs so you could match it on the gauges... :drool: --- i sold one only last September to buy an Elise for a test car ,and that feature i loved and the way the shift light worked with it.
Kudos!
this i like, thanks for taking the time, I have answered next to your questions
Discussion Starter #19 (Edited)
