41 - 60 of 1657 Posts
Discussion Starter #41
^^^Camera display is a great idea.
I don't see the need to simulate the uneven lighting of the stock night mode. Should be nice and even, adding functionality, otherwise it's not really an upgrade.
Definitely would like to see oil pressure and temp.
Would like to be able to spec units (psi vs. bar, degF vs. degC, etc).
Lap and G functions also cool. What is the input for these?
Beautiful work, garw. I subscribed to your YouTube channel...
The classic screen was meant to be as accurate as possible to the original including how it looks at night
..but a few people have said its not for them, as they dislike it in their current analogue cluster..... what could replace it ?
naturally the authentic look will always be available but an option to switch could be added , maybe just even lighting with a color option ?
G funtion is built into the unit with a calibrate function
lap timer is a simple input to be used with circuit lap timers,
the beacons on track, usually infrared receiver in your car
they are the most accurate i believe
the extra connector is for expansion, and due to popular demand
i will expand the plug to include analogue inputs for pressure sensors etc
Discussion Starter #42
Discussion Starter #43
1. TPMs: tire pressure monitor for all 4 wheels
2. Rearview and frontview cameras
3. Built-in radar detector showing the direction of the laser (like the Valentine 1)
if its a canbus TPMS then it can be easily added
cameras not yet , no technical issue but its a small screen
radar detection , mmmm didnt think of that , not really in that
market
Elise Driver
market
I wouldn't expect you to make a radar detector, just a way to display the alert arrows from the Valentine 1 detector (arguably the best one on the market). I imagined the whole screen starts flashing red and points to the direction of the ��
market
Ok , I get it if the detector has an output then it could be used . It would be a generic alarm that is triggered by a particular input .
Discussion Starter #49
how does the lap timer work?
How would it recognize when to start the clock and when to reset the clock?
laptimer is an external input designed to work with track laptimers
beacons as they are known, the car has a receiver which gets triggered by a transmitter on the side of the track.
guys take their own an leave the transmitter in the pits sometimes
but its fairly standard stuff and the most accurate
so pass the beacon and the timer starts, pass again and it will reset and save that lap to the previous lap reading, a list is then kept in another screen of all your lap times .
Discussion Starter #50
Wow.
Sorry if I missed it, is this Android based? What is the CPU spec of tablet?
Have you checked with the UK, Aussie or Kiwi blokes?
And again, just wow.
No sorry its not android, its a bespoke embedded operating system
built for the job.
And its not a tablet, it uses an embedded dual core arm processor
with accelerated graphics
although arm processors are used in nearly every mobile device
so you would find it in a tablet, phone,
most high end cars with LCD instruments also use arm processors
they have the best performance per watt, so perform well and run very cool no fans needed etc.
UK is its origins , that's were I am based and currently testing.
not sure how to get word to the Aussies and Kiwi's
I'm IN! TAKE MY MONEY!!!! :crazyeyes:clap::bow::up::up:
Discussion Starter #52
such a different audience here :smile2: i like it
but send me a message if you want more info on its next stage
or just hang on and I will keep you updated on details of the production release
Discussion Starter #56
All USA models from 08 on are fitted with TPMS. Not sure if European models have them?
yes you are right , its a canbus warning lamp
but there is no pressure value sent over the canbus, only an on/off message for the warning lamp
...but thanks for pointing me back to the canbus codes, as I found a USA spec bit , so the USA cars
will identify themselves over CANBUS so I can preset to deg F etc.
Thanks
Thanks for your response.
Clearly a lot of work (very impressive work) has gone into replicating the appearance of the original display. But, not to put too fine a point on it, what would an end user get out of it? I mean, I already have a display that looks like the original; it's in the car right now...
If I were able to develop this myself (not remotely possible), I'd have three screens:
1. Street display - a central round-dial speedo with large digital speed indicator in the center; under the digital speed, a smaller digital selected gear indicator. Tach display on the left in the form of a partial arc or moving tape display. On the right, partial arc or moving tapes for fuel level, coolant temp, oil pressure, oil temp. If space is too tight, the oil data could be minimal or even reduced to just warning lights. 2016 Cadillac CT6 is a good model for this layout.
2. Track display - much as you have it now. Tach is a full round dial, maybe put the redline at 12:00, GT40-style. Digital gear indicator and speed. Oil pressure and temp now larger than fuel level.
3. Settings, lap times, G load datalogged by lap
I'm very interested to see how your product turns out, quite promising so far. Do you have an estimate as to when you might be ready to produce finished units?
[...]If I were able to develop this myself (not remotely possible)[...]
I think that something similar to this would be quite doable with an arduino uno, an SD shield (for image storage), a CAN shield (It is trivial to read the CAN bytes or inject others onto the bus) and a TFT display. This is just speculation though.
I have long wanted some kind of map/GPS and internet connected display behind the gauge cluster so that I would not have to get out a phone for navigation. However, I harbor reservations due to potential complications with losing the original odometer reading. I understand that someone could have the proposed device programmed with a pre-set odometer value. However, how would the person who is selling this display confirm that the number is honest? What about someone buying a car that had this installed into it- how could they confirm that the odometer reading was accurate? Although I suppose that anyone could disconnect their OEM cluster and thereby make the displayed number inaccurate...
Is this display only intended for people who don't care about this kind of thing? Is there any chance that this display could be installed over top of the OEM gauge cluster (and just splice off of the wire connections) in order to maintain the original odometer accounting?
(sorry for being a debbie downer; this display looks pretty great and I didn't leave any positive comment)
Ok I will be the first to say it. Read the whole post, number 16. This is what it says!
The odo starts from zero, but a preset value can be requested if needed to match the original.
