We have taken front and rear clams off but have not attempted the sills. I cant see it being anymore difficult as long as its not bonded to the frame.
Ok.. I'll just post the manual. Rather than saying over and over again it's harder.
From the book:
The sill panels incorporate the ‘A’ and ‘B’ posts, and are bonded to the chassis, windscreen frame and
rear bulkhead panel. The sill bottom flange, and rear end of the will top flange are bonded into grooves in the
chassis main side rails and it is necessary to cut the sills in the course of their removal: It is not practical to
attempt to remove a sill panel intact for later refitment. If sill damage occurs which is not repairable ‘in situ’,
the sill panel should be renewed.
To Replace Sill Panel
A short section of sill flange underlaps the windscreen frame buttress flange in the front wheelarch area
and requires that some cutting and laminating of the new panel is required on assembly.
1. Remove front and rear clamshells (see sub-sections BR.5, BR.6), dash panel (BR.13) and door hinge
bracket (BR.8).
2. Remove the door latch striker pin and washers, noting the assembly sequence. Remove the door sill trim
panel from the chassis and the door ajar switch from the sill panel.
3. Use a sealant cutting knife to cut the adhesive bead between sill and chassis/body panels.
Note:
- In the front wheelarch area, a short section of the sill flange underlaps the windscreen frame buttress
flange. Unless the windscreen is also to be removed, it will be necessary to cut the sill around this flange
in order to release the sill.
- The bottom edge of the sill, and the rear part of the top edge, locate in grooves in the chassis side frame,
and may not readily be cut out with the sill intact. Cut the sill as necessary to release the panel, and then
remove the remaining edges of the panel from the chassis using a suitable cutting knife.
- Cut the sealant around the door hinge post aperture.
- Cut the sealant between the panel and roll over bar.
Bonding
4. Remove excess sealant from all the bonding areas on the chassis and body panels. It is not necessary to
remove all traces of old adhesive, but any remaining adhesive must be securely bonded and be cut with
a scalpal blade to leave an even thickness of 1 - 2 mm.
5. If necessary, cut the top front corner of the sill flange to allow mating of the panel around the windscreen
butress flange. Dry fit the sill and fettle as necessary to achieve a good fit. Note that a new sill will require
an alloy right angle bracket (A120B0053F) riveting to the rear end of the sill panel to form a bonding surface.
Holes are pre-drilled, with two pairs of holes in the bracket to suit Rover and Toyota powertrain cars. For
Toyota powertrain cars, use the innermost holes in the bracket to pull the sill panel furthest inboard.
6. Before preparing the surfaces for bonding, ensure that the necessary pipes and cables are fitted to the
chassis side rails:
RH side: - heater feed pipe
- brake pipe
- alloy spigot for side impact foam
LH side: - heater return pipe
- brake pipe
- clutch pipe
- servo vacuum hose
- main battery positive cable
Check that the following components are fitted into the composite sill:
RH side: - 2 a.c. pipes (if applicable)
- oil cooler return hose (if applicable)
- side impact foam
- foam baffle
LH side: - oil cooler feed hose (if applicable)
- side impact foam
- foam baffle
7. Prepare the bonding surface of the new sill panel with Betaclean 3900 and Betaprime 5404 (see subsection
BQ.5). Prepare surface of the old adhesive bead on the chassis and body panels Using Betawipe
4000 (see sub-section BQ.5).
8. Apply a bead of Betaseal/mate adhesive (see sub-section BQ.5) to the bonding surface on the chassis and
body and fit the sill panel into position, first locating the sill bottom edge into its chassis slot, and press all
around the joint to ensure sufficient spread of adhesive. If necessary, use a spatula to smooth or remove
any extruded adhesive, and to neaten any visual areas. If necessary, add adhesive to the joint around
the door hinge post, and to the windscreen frame, and smooth with a spatula.
9. Clamp the panel into position until the adhesive has cured (see sub-section BQ.5).
10. If the top front corner of the sill flange has been cut to fit around the windscreen butress flange, this area
should be reinforced as follows: Roughen the surface of the windscreen buttress flange and the adjacent
sill panel in the modified area, and lay up two pieces of chopped strand mat across the joint.
11. Refit the dash panel, front and rear clamshells, doors, both wheelarch liners and other components as
necessary.
