I don't know what the AC relay problem is. I can't search because of this POS blackberry curve. I can't even read the responses without replaying first, and seeing what's written below. I will check that problem out once I have access to a computer or some mobile device that isn't total trash. I should check to see if he was using the AC. Thank you for your responses.
SERVICE Date: 03.08.06 2006/20
BULLETIN Model: '06 Elise/Exige a.c.
Service Manager Service Reception Supervisor Parts Manager
Lotus Cars Limited, Norwich, Norfolk, NR14 8EZ. England.
CLASS 3
TITLE: Momentary engine power interruption.
REASON: It has been found that on a very small number of '06 model year cars, with an unfavourable tolerance
a.c. control module, it is possible under some circumstances that sparking across the a.c.
compressor relay contacts can cause a voltage spike which results in the engine ECU resetting.
This will be experienced as a momentary interruption of engine power, and is likely to occur only
very occasionally. It is also possible that a throttle related trouble code may be set. e.g. P0638.
Action: If this symptom should be reported, it is recommended to replace the a.c./fan control module
A117M0038F
