My 88 Esprit has a 3rd brake light and rear window defroster. The wiring for the hatch has been hacked up and removed. Can someone fill me in on how the wires run? I know they run to the lift struts and transmit through them. Does the hinge act as the ground path, as it only has two struts, and two circuits? Using the multimeter there was no good ground to the hatch. Looks like the left side is the defrost and the right side is the brake light, but the left over wiring looks a bit strange to me. The left strut appears to have been a ground at some time, but really I can't tell.
I have ordered new struts with the wiring tabs, as the currently fit ones don't have the tabs. Then I will get my 3rd brake light working to pass inspection.
Thanks
Thanks
