Engine Light Fixed
My "Check Engine" light came on at 52 miles!!! I had just picked the car up from the dealer, and now, 50 miles later, a problem. I was starting to wonder about this car on the first day I owned it.
That was on Saturday, called the dealer and he said to bring it back in on Monday, if it hadn't "self-corrected" by then.
On Monday, I was at the dealership bright and early and they got right on it. Turns out, according to the tech guy, that on brand new cars that are started up and just moved around the showroom or run only for a few minutes, the O2 sensor gets "coated with gas before the sensor has time to fully heat up". The engine is turned off with all that "gas" on it. Doing this several times causes an error code to generate and the light pops on. The tech reset all the codes and I haven't had a problem since. That was 3 days ago. If the light had come back on they would have replaced the O2 sensor. (I hope that explanation makes sense??? :shrug: )
The tech also said that he has had this happen on several other new cars they delivered. I'll take him at his word and hope the light stays off.
Wayne
