1 - 7 of 7 Posts
The engine malfunction light light keeps going on and off so I got it scanned and it gives the following error:
Plant Communication Device Gadget Audio equipment Gas
How worried should I be and has anyone else faced the same problem?
The code reads like you have a loose fuel pump wire, so I’d definitely try to fix that on my own terms rather than on the side of the road. Has the motor ever cut out or hesitated on you? There’s always the possibility of a false alarm, but I’d rule out a wiring issue first.
It has not. Another thing I noticed is that the light goes away when I turn the ignition on and comes back on when I turn it off. Does that tell you something?
That’s just what every OBDII car does to confirm the light works if I understand what you’re seeing.
I am no expert at all. So you are saying that I don't need to worry and I can drive it?
I’m just saying that the CEL light will come on at key on and then turn off when the engine is running, that’s the part that’s normal. Having an active code isn’t normal, and the service manual actually says that code won’t trigger a CEL. Since you have never noticed it cutting out, maybe just clear the code and check occasionally to see if it comes back. Could be as simple as an old issue when a battery went flat or something like that and was never cleared.
Discussion Starter · #7 ·
Ohh. Thank you so much!
1 - 7 of 7 Posts
