I recently upgraded my lower engine mounts with inserts, and discovered that some of the torque settings in the instructions were incorrect (discovered the hard way - stretched bolts, but fortunately on the ones easiest to replace and that used nuts) . The big concern is that overtightened bolts can break under load. The torque settings are not listed in the service manual. So, I tried to examine the bolts to determine their size and class, and looked up the proper torque value for the bolt. Of course, this says nothing about what the female threads in the engine, transmission or the frame can handle, but the bolt specification is a start.
First, here are the two best references I could find on recommended torque for metric bolts. I liked the first one better, but the second does give some lubricated values. Unfortunately, there is a lot of variation in recommended torque settings out on the web, but these two sources seemed consistent with most, had more information, and in general appeared to be more reputable. You might want to save them to your computer in case the web sites vanish.
http://www.imperialsupplies.com/pdf/A_FastenerTorqueCharts.pdf
Metric Bolt Torque Table - CNCexpo.com
(By-the-way, Bolt Depot's recommendations seemed consistently higher than other references, so I didn't use them. Nor were they as complete in their specifications as compared to the others.)
I was upgrading the lower engine mounts. Here are the bolts I examined:
1) Rear lower mount:
1a) mount to frame, rearmost pair (with nuts)
Class: 8.8 (says so on the bolt head)
Diameter: M10 (10 mm)
Pitch: 1.5 mm (thread spacing, which is how metric bolts are specified)
Plated (looks like zinc)
Recommended torque for this specification: 38.25 foot-lbs
1b) mount to frame, forward pair (bolts into frame)
Class: 8.8 I think (not listed on the bolt)
Diameter: M8 (8 mm) I think. I forgot to measure it before installing, but it was definitly a size smaller than the other pair of bolts (1a).
Pitch: 1.25 I think (again, forgot to measure, but the threads didn't seem as fine as a 1.00 pitch)
Recommended torque for this specification: 18.75 foot-lbs
(of course, you can't fit a torque wrench in the space, so you just have to estimate your strength)
1c) big center bolt through mount
Class: 8.8 I think. (The only marking on the bolt head was a lower case b with a dot over it. I don't know what that means, but Lotus generally doesn't use the higher class bolts.)
Diameter: M12 (12 mm)
Pitch: 1.5 I think (measured it, but lost my note. This my best recollection.)
Plated (not sure with what)
Recommended torque for this specification: 69 foot-lbs
2) Forward lower mount
2a) mount to transmission housing
Class: 8.8 I think. (The only marking on the bolt head was 11. I don't know what that means, but Lotus generally doesn't use the higher class bolts.)
Pitch: 1.25
Recommended torque for this specification: 40.5 foot-lbs
2b) big center bolt through mount
Pitch: 1.25 I think (measured it, but lost my note. This my best recollection.)
It would be good if others could check the bolt measurements and classes, and add in the bolts I didn't list, such as the upper side engine mount bolts.
The bolts I damaged were listed in 1a above. I ended up replacing them with higher class bolts (10.9), and torqued them to the appropriate specification for that class in the Imperial Supplies chart above.
Pitch: 1.25
