Edit: These instructions are followed by the Entry Sill Top Trim Installation Tutorial
I recently bought some sweet CF sills from Jacob, but couldn't find any instructions on how to remove the stock sills, so I'm writing one up here. It took me over an hour to figure it all out, but realistically, the whole procedure should have only taken twenty minutes.
While some steps are covered in other threads, such as in My Dash Removal Instructions and Sill Removal & Replacement..., there's nothing that did a step-by-step tutorial with pictures of just the sill removal. Also, door sill removal pics mentions removing seven screws, but you only need to remove three from each side of the car for the removal, though you do need to remove seven from each side for the installation.
- First, locate the rubber mat in the coin pocket (cubby).
- Using a flathead screwdriver, push against the mat to remove it.
- The mat should be relatively easy to remove, since it's only held by two strips of double-sided tape.
- Next, remove the screws that were underneath the rubber mat, in the coin pocket.
- Near the opening of the door, remove the single screw. Using an old credit card, work underneath the sill to loosen the Spooge.
- Loosen the Spooge on both sides of the sill top trim.
- Towards the rear of the car, work underneath the sill as much as possible. There is a thick double-sided tape under this, and will be your main resistance to removing the sill top trim.
- Pull the sill up, hard. Don't jerk it or else you might hit your head on something, but gradually pull harder and harder until the Spooge and double-sided tape give way. This will take a lot of effort.
- With the sill lifted slightly, pull the sill toward the rear of the car, and it should pop right off. Note: If you will also be installing sills, you might want to remove the other two screws in the coin purse first. See Entry Sill Top Trim Installation Tutorial.
- Be careful that you don't drop and screws into the hole where the sill used to be. I did, and it was really painful to get it out. Basically, it falls all the way to the bottom of the aluminum chassis.
- The sill top trim is removed. You can use the stock padding if you're installing your CF sill. You'll have to pull hard on the stock padding as well to remove it. To install a sill, be sure to use 3M tape.
- Use the old credit card as a scraper to remove any remaining Spooge or double-sided tape.
- And this is why you want to use an old credit card.
