Many owners attempted changes to the spring rates. Others changed their shocks and springs with some mixed results. Ride quality is a function of the balance between understeer and oversteer and often does not respond well to random changes.
Therefore,
I'd like to start a discussion on the subject and compile collective knowledge in one place.
(DD required when using data below)
88-93 Esptit Turbo GEO
front:
camber -0°12' to - 0°42'
castor 2°55' to 4°05'
toe 0°00' to 0°09'
rear:
camber -0°20' to -0°50'
toe 0°21' to 0°30'
LOTUS ESPRIT S300 SUSPENSION GEO
FRONT
Camber -0°39’ to -0°51’
Caster 3°05’ to 3°35’
Toe -0°02’ to -0°06’
REAR:
Camber -0°52’ to -1° 08’
Toe 0°09’ to 0° 12’
Non-SE 89 (17% anti-dive), (is 88 Federal the same?)
Front: Rate– 22.8 N/mm / 130 Lb/in, Free Length–369mm (14.5”), Static Length– 203mm (10”), 585# preload, ride hgt 170mm
Rear: Rate– 27.5 N/mm / 157 Lb/in, Free Length–334mm (13.15”), Static Length– 205.7mm (8”), 808# preload, ride hgt 170mm
17 mm dia. front anti-sway bar
89+ SE (22% pro-dive)
Front: Rate– 29.1 N/mm /166 Lb/in, Free Length–372mm (14.6”), Static Length– 219mm (8.62”), 992# preload, ride hgt 190mm
Rear: Rate– 27.5 N/mm / 157 Lb/in, Free Length–347mm (13.7”), Static Length– 218mm (8.6”), 800# preload, ride hgt 170mm
S4/S4s
Front: Rate – 41 N/mm / 234 Lb/in, Free Length - N/A, Static Length– 214mm (8.43”)
Rear: Rate – 45 N/mm / 257 Lb/in, Free Length - N/A, Static Length– 227mm (8.93”)
15 ? mm dia. front anti-sway bar
The front damper platform height for each of these measurements is 59mm. The rear platform height is 115mm. The extended/compressed length for the front is 12in./10in., and the rear is 16in./12in.
About G-car rates
http://www.thelotusforums.com/forums/topic/14042-spring-rates/?p=518974
So, what rates have you used, why and what are the results?
Therefore,
front:
toe 0°00' to 0°09'
rear:
toe 0°21' to 0°30'
FRONT
REAR:
Toe 0°09’ to 0° 12’
SPRINGS:
86/87/(and 88?) Turbo Esprit Wiki - Esprit.TechnicalDataNon-SE 89 (17% anti-dive), (is 88 Federal the same?)
S4/S4s
About G-car rates
