Your 88 is only adjustable for front toe easily.
You can adjust rear toe by removing or adding shims at the trailing arm pivot bolt.
You can adjust the front caster by removing or replacing shims on the upper wishbone pivot. Both those adjustments are really not necessary very often.
Later cars after 1994 had the adjustable camber on the rear upper top links and the offset shims on the upper front wishbones.
