1 - 2 of 2 Posts
New Evora 400 owner here,
Does the charge cooler and header reservoir both use the same type of coolant? Both of mine are above the Min level but not by much. Can I top them both off, and if so do they use the same coolant type?
I heard that Lotus recommends Peak Global Lifetime coolant. Anybody else using it? Thanks for the help!
Illegal Alien
Does the charge cooler and header [engine radiator] reservoir both use the same type of coolant? Both of mine are above the Min level but not by much. Can I top them both off, and if so do they use the same coolant type?
Same coolant From Service Notes:
Engine coolant
Capacity
Antifreeze Type Colour
Approved product
12.5 litre (Includiing 50% concentration of 6.25 litres of anti- freeze)
Ethylene glycol antifreeze with OAT corrosion inhibitors Red
PETRONAS Paraflu Up
Charge cooler coolant
Capacity
Approved product
5.5 litre (Includiing 50% concentration of 2.25 litres of anti -freeze)
PETRONAS Paraflu Up
Toyota Long Life (pink stuff) is recommended in place of Petronas
1 - 2 of 2 Posts
