1 - 5 of 5 Posts
What are these wires? I assume white and gray are ground and blue is power? No instructions were given when buying the OEM DRL kit
1260206
What's on the other end of those wires? The 400 wiring diagram doesn't mention those wire colors if they're coming from the module.
Just what's in the service notes. They can be downloaded from VSIC for a nominal fee.
What I posted above is from the wiring diagram for the DRLs. One wire brings +12V to the module (pin A2), and should be blue w/ a purple stripe. There should be a black wire on pin A1, and that goes to ground. The other 2 wires should be for the LEDs themselves in series; pin B-A provides +12V via a blue w/ pink stripe wire to the RH LED, and then this is wired to the LH LED, and completes the circuit via a black w/ pink stripe wire, which is connected to pin B-B, and should be ground.
My shop guy put the two wires that look like ground to ground and the blue wire to power on a battery and they out up. Problem solved. ?
1 - 5 of 5 Posts
