1 - 16 of 16 Posts
2017 Evora 400 - IPS
2017 Evora 400 with 6k miles
Got MIL and Transmission telltale lights today highway speeds 80-90mph in Sport Mode.
Luckily I have Bluetooth code scanner always connected so was able to pull over and read & reset the codes:
P0700 - Generic TCU light
P1613 - Generic ECU light
P0751 - Shift Solenoid "A" Performance or Stuck off
After reset drove about another 60 miles and lights did not come back on.
Reading the IPS service manual, it seems like P0751 is what caused the other lights.
However from what I am understanding from the manual is that P0751 - Stuck off occurs at
speed of 0km/h and gear 1 among other criteria. However this occurred in high gear (5 or 6) at high speed
Any suggestions on what may have caused this or what else to look out for?
I am the 2nd owner and not sure how well the IPS was treated by previous owner. My first thought was to try changing the AT Fluid but it doesn't look that easy of a DIY job and the closest dealer is 200 miles away
Font Gadget Screenshot Electronic device Technology
Font Number Screenshot
Any other symptoms, such as slow or no shifting, no or little power when pressing on accelerator, jerky or bucking feeling when shifting?
Car went into limp mode when CEL and TCU lights came on. After resetting code no issues in acceleration or power. Only thing noticeable was the automatic downshift from 2 to 1 in stop & go traffic. The gear 2 to 1 automatic downshift feels a bit clunky
Battery condition please
Reactions: Catsailr27
Discussion Starter · #7 ·
the scan tool shows 12.5 v with ignition in accessory mode ( with all lights, radios etc off) and 14v with engine started.
not sure if there is a better way to get battery status without having it load tested at one of the auto parts stores.
car was on trickle charger for about 4 hours prior to this test and is always on a charger if not being driven for a period longer than 48 hours
having a dealer change the AT fluid is a good idea. It needs to be done at a certain temperature. Their notes may say the wheel has to come off but it doesn’t have a side drain like some bites say.
From third gear at around 2k rpms, accurate slowly, if 4th doesn’t engage well, that may be a sign. This is what happened to me before I changed the fluid.
also, there is a TCU update available that your dealer can load.
Administrator
Evora can be fickle with a marginal ground or battery. Many weren't well treated at dealers and would die then get charged repeatedly instead of left on trickle charger. I would have the battery load tested for peace of mind and when re installing check your grounds at bulkhead and engine. I use noox on the terminals to prevent corrosion.
Why would battery be an issue when car is running at highway speeds?? Alternator should be doing the job.
Battery issues tend to be the root of all electrical evils on a Lotus, and Alfa, etc
While yes the alternator is doing the job at highway speeds, the battery always provides a 'bottom' which it cannot drop below, even for an instant
Most cars will run with no alternator at all[funny oooold story follows] but it is always possible for random events to happen with modern computer controlled cars and variable voltage. Computers think quickly and momentary drops in voltage that would not dim a lightbulb might glitch an ECU
I am not saying that this is the cause of this issue, not at all, just that computers, variable voltage, weirdness............for instance, the SPM on the Elise/Exige has apparently no diode or bleed resistor in the AC clutch relay, and it glitches the ECU for a moment every time the AC clutch engages or disengages or something.
So, 1981
driving my very rotten 1970 Opel GT to work for 2nd shift
Suddenly crash crash crash rattle thump like I ran over a rock in the road
Look in the rearview and my battery is sitting in the middle of the road
You see, the Opel GT had the battery on a tray forward of the radiator, and since it had long since rotted away, it just sat on the nose, which was also rotten, and since I had several cars and one [previously] good battery, the terminals were loosish. Hit some imaginary bump and the battery just slid out of the car
Car didn't miss a beat.
I stopped, picked up my bleeding battery and drove on to work. Either the Ebrake worked or it happened to be a level patch of road, I cannot remember, but if not, I would have been living the gate scene from 'The Gods Must be Crazy'
Threw the battery back in during lunch break, got a jump at midnight and drove home. Got a junkyard battery the next day.
Discussion Starter · #13 ·
Update
did a 200 mile trip today. No issues with shifting, power etc.. and no CEL or TCU lights despite driving the vehicle hard and a few redlines.
1/2 way thru the trip the fuel gauge went blank and low fuel light came on. Once again the bluetooth code scanner came in handy and detected a P0461 Fuel Level Sensor A circuit issue. I rest the code and fuel gauge started working again. Filled up the tank just for good measure.
I think its time to change the battery on this 400. Any recommendations?
Update
I think Interstate makes one of the few that fit. You will see many comments in favor of lightweight and/or racing-style batteries and nothing against them, and of course they weigh a lot less, but a "regular" battery may be best depending on what kind of driving you do. Lotus seem to be famous for mystical parasitic drains, so the advantage of a regular battery may be that you can go a week (or two, YMMV) without attaching a battery maintainer and still be okay. But I keep mine on most of the time.
No argument with anything you said.
Worth pointing out though, that swapping a lead acid/AGM battery with a lithium battery is one of the best bang for the buck lightweighting you can do. True value.
1 - 16 of 16 Posts
