1 - 7 of 7 Posts
I wanted to see if this is unique to me. With engine cold (sat overnight), there's about a 50% chance my Evora 400 will not start on the initial crank of the starter. The second time it always fires right up. It's a manual, garaged, low miles... Anyone?
Yup. For me, it is about 90% of the time if the car has been sitting overnight or longer. I have almost 7k miles on my 2017 E400. I have tried turning the key, waiting about 20 seconds while I put on my seatbelt, etc., and then starting, but even that trick doesn’t work much of the time. My thought was that the fuel pump needed time to get fuel to the engine. But like you, it always starts right up on the second try. It also always starts right up later on that same day. Maybe something to do with fuel delivery in cold engines? Or, maybe the trolls in the engine drink too much and need not one, but two swift kicks to get out of bed?
Sent from my iPad using Tapatalk
Haven’t experienced this at all. Seems like something isn’t right. Definitely not TADTS.
I've had this happen occassionally in my NA Evora. I press the security button and wait to hear the fuel pump prime before I crank it. It's not an issue but a minor annoyance. Buf if some one knows better, please chime in.
start
it seems if I do not hit the starter button just right, nothing happens
otherwise it fires up immediately
2017 Lotus Evora 400
In my case after that happening I started to charge the battery more often an now starts immediately.
My 2017 E400 generally starts on first try. When it has not done so, it was usually when I just briefly hit the starter button but did not hold it for a second or two. From what I can see, the start button seems to actually, directly control the starter - meaning that if you hold it down longer, the starter will actually crank longer. In my old M3, the button was effectively there to kick off the start up process and whether I held it for one second or three, it didn't matter since the ECU seemed to control the starter directly. I would never crank any starter excessively but basically if I just touch the starter button or my finger slips after hitting it, it might not turn over but as long as I hold it for a second or a little more it seems to fire up no problem. I also wait a few seconds after turning key for the ignition immobilizer process before depressing the start button.
As others have said, maybe a battery issue as well?
1 - 7 of 7 Posts
