1 - 8 of 8 Posts
Does anyone know whose ABS unit Lotus use. Earlier Elises used GM/ Vauxhall units but I can't find what is used on the Evora.
Illegal Alien
Bosch
Thanks Julian. I have an Autek reader that has the ability to cycle the ABS unit for bleeding. Unfortunately it can only select by car model and there are too many for me to cycle through to find one that communicates. Do you happen to know what other car model this Bosch unit may have been used on?
It looks like Lotus uses a Bosch 8.1 ABS/ESP brake system modulator. And, if I've found correct information, it appears that the same system is used in the Audi A5. Although, I cannot find a year range.
If I am incorrect, please let me know so that I can remove this info so it would be out there for others...
Bruss, seen as you run your S1 Evora at track a lot, what pads do you use?
@chromeorange. Thanks for the info, tested today and the m629 auto scans on Audi. Unfortunately it didn't find anything to communicate with.
It did however find Porsche 911 abs unit to communicate with. The shame. It didn't offer the abs cycle I was looking for though.
@brgelise. I tried ds 3500 and cl6's but both were too fierce for me on trackdays. If I was racing I'd probably go for the ds 3500's..
The 2500's seem to me to be a perfect combination of immediacy where required and graduated for old blokes who don't want to go through the screen everytime they get it wrong :)
Thanks, by chance are you getting a brake light telltale on your dash read out? I have had it for a year plus now, Lotus can't figure it out, and everything works perfectly.
I have been running Hawk DTC 70's for years now but the size I used front and rear will longer fit when I install my Girodiscs. I took years to get there, but I have got the braking thing figured out pretty well now and its where I catch lots of big HP hardware like GTR's etc. They may walk away on straights, but I take it all back before the corner. Where ever they brake, I brake deeper!! It truly is a strength of the vehicle.
Discussion Starter · #8 · (Edited)
Absolutely agree on the braking. I'm now running the grooved discs from Inowosit konetic. Even on the standard discs I've been outbraking most other sports cars. I was fortunate enough to drive a well modified GT4 on track and the brakes on that were just poor compared. It did have other advantages but even the owner commented on the better brakes on the Evora.
Edit: No telltale. I was just looking to use an existing Autek to cycle the abd unit for bleeding.
Also the GT4 was the Porsche , not the Evora race car.
1 - 8 of 8 Posts
