1 - 2 of 2 Posts
Posting the ECU Fault codes for easier search reference as they don't come up in a search when you're stuck on the road somewhere using your mobile to be a roadside mechanic. The number at the end is the page number in the "Service Notes" doc that describes it more.
From the Service Notes Section EMR - Version 2009:
EMR.1 - DIAGNOSTIC TROUBLE CODE (DTC) LIST
P0011 A Camshaft Position - Timing Over-Advanced or System Performance - Bank 1 11
P0012 A Camshaft Position - Timing Over-Retarded - Bank 1 11
P0014 B Camshaft Position - Timing Over-Advanced or System Performance - Bank 1 11
P0015 B Camshaft Position - Timing Over-Retarded - Bank 1 11
P0016 Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor A 12
P0017 Crankshaft Position - Camshaft Position Correlation - Bank 1 Sensor B 12
P0018 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor A 12
P0019 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor B 12
P0021 A Camshaft Position - Timing Over-Advanced or System Performance - Bank 2 11
P0022 A Camshaft Position - Timing Over-Retarded - Bank 2 11
P0024 B Camshaft Position - Timing Over-Advanced or System Performance - Bank 2 11
P0025 B Camshaft Position - Timing Over-Retarded - Bank 2 11
P0076 Intake Valve Control Solenoid Circuit Low - Bank 1 13
P0077 Intake Valve Control Solenoid Circuit High - Bank 1 13
P0079 Exhaust Valve Control Solenoid Circuit Low - Bank 1 13
P0080 Exhaust Valve Control Solenoid Circuit High - Bank 1 13
P0082 Intake Valve Control Solenoid Circuit Low - Bank 2 13
P0083 Intake Valve Control Solenoid Circuit High - Bank 2 13
P0085 Exhaust Valve Control Solenoid Circuit Low - Bank 2 13
P0086 Exhaust Valve Control Solenoid Circuit High - Bank 2 13
P0101 Mass or Volume Air Flow Circuit Range/Performance 14
P0102 Mass or Volume Air Flow Circuit Low Input 14
P0103 Mass or Volume Air Flow Circuit High Input 14
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance -
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input 16
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input 16
P0111 Intake Air Temperature Sensor 1 Circuit Range/Performance -
P0112 Intake Air Temperature Sensor 1 Circuit Low 17
P0113 Intake Air Temperature Sensor 1 Circuit High 17
P0116 Engine Coolant Temperature Circuit Range/Performance 19
P0117 Engine Coolant Temperature Circuit Low 19
P0118 Engine Coolant Temperature Circuit High 19
P0122 Throttle Position Sensor 'A' Circuit Low 21
P0123 Throttle Position Sensor 'A' Circuit High 21
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature) -
P0131 O2 Sensor Circuit Low Voltage (Pre Catalyst) - Bank1 25
P0132 O2 Sensor Circuit High Voltage (Pre Catalyst) - Bank1 25
P0133 O2 Sensor Circuit Slow Response (Pre Catalyst) - Bank1 25
P0134 O2 Sensor Circuit No Activity Detected (Pre Catalyst) - Bank1 25
P0135 O2 Sensor Heater Circuit (Pre Catalyst) - Bank1 25
P0137 O2 Sensor Circuit Low Voltage (Post Catalyst) - Bank1 28
P0138 O2 Sensor Circuit High Voltage (Post Catalyst) - Bank1 28
P0139 O2 Sensor Circuit Slow Response (Post Catalyst) -
P0140 O2 Sensor Circuit No Activity Detected (Post Catalyst) - Bank1 28
P0141 O2 Sensor Heater Circuit (Post Catalyst) - Bank1 28
P0151 O2 Sensor Circuit Low Voltage (Pre Catalyst) – Bank2 25
P0152 O2 Sensor Circuit High Voltage (Pre Catalyst) – Bank2 25
P0153 O2 Sensor Circuit Slow Response (Pre Catalyst) – Bank2 25
P0154 O2 Sensor Circuit No Activity Detected (Pre Catalyst) – Bank2 25
P0155 O2 Sensor Heater Circuit (Pre Catalyst) – Bank2 25
P0157 O2 Sensor Circuit Low Voltage (Post Catalyst) – Bank2 28
P0158 O2 Sensor Circuit High Voltage (Post Catalyst) – Bank2 28
P0159 O2 sensor Circuit Slow Response (Post Catalyst)
P0160 O2 Sensor Circuit No Activity Detected (Post Catalyst) – Bank2 28
P0161 O2 Sensor Heater Circuit (post Catalyst) – Bank2 28
P0171 System Too Lean – Bank1 31
P0172 System Too Rich – Bank1 31
P0174 System Too Lean – Bank2 31
P0175 System Too Rich – Bank2 31
P0222 Throttle Position Sensor 'B' Circuit Low 21
P0223 Throttle Position Sensor 'B' Circuit High 21
P0261 Cylinder 1 Injector Circuit Low 33
P0262 Cylinder 1 Injector Circuit High 33
P0264 Cylinder 2 Injector Circuit Low 33
P0265 Cylinder 2 Injector Circuit High 33
P0267 Cylinder 3 Injector Circuit Low 33
P0268 Cylinder 3 Injector Circuit High 33
P0270 Cylinder 4 Injector Circuit Low 33
P0271 Cylinder 4 Injector Circuit High 33
P0273 Cylinder 5 Injector Circuit Low 33
P0274 Cylinder 5 Injector Circuit High 33
P0276 Cylinder 6 Injector Circuit Low 33
P0277 Cylinder 6 Injector Circuit High 33
P0300 Random/Multiple Cylinder Misfire Detected 34
P0301 Cylinder 1 Misfire Detected 34
P0302 Cylinder 2 Misfire Detected 34
P0303 Cylinder 3 Misfire Detected 34
P0304 Cylinder 4 Misfire Detected 34
P0305 Cylinder 5 Misfire Detected 34
P0306 Cylinder 6 Misfire Detected 34
P0327 Knock Sensor 1 Circuit Low 36
P0328 Knock Sensor 1 Circuit High 36
P0332 Knock Sensor 2 Circuit Low 36
P0333 Knock Sensor 2 Circuit High 36
P0335 Crankshaft Position Sensor “A” Circuit Range/Performance 37
P0341 Camshaft Position Sensor “A” Circuit Range/Performance (Bank 1) 38
P0346 Camshaft Position Sensor “A” Circuit Range/Performance (Bank 2) 38
P0351 Ignition Coil “A” Primary/Secondary Circuit 39
P0352 Ignition Coil “B” Primary/Secondary Circuit 39
P0353 Ignition Coil “C” Primary/Secondary Circuit 39
P0354 Ignition Coil “D” Primary/Secondary Circuit 39
P0355 Ignition Coil “E” Primary/Secondary Circuit 39
P0356 Ignition Coil “F” Primary/Secondary Circuit 39
P0366 Camshaft Position Sensor “B” Circuit Range/Performance (Bank 1) 38
P0391 Camshaft Position Sensor “B” Circuit Range/Performance (Bank 2) 38
P0420 Catalyst System Efficiency Below Threshold (Bank 1) 40
P0430 Catalyst System Efficiency Below Threshold (Bank 2) 40
P0441 Evaporative Emission System Incorrect Purge Flow -
P0442 Evaporative Emission System Leak Detected (small leak) -
P0444 Evaporative Emission System Purge Control Valve Circuit Open 45
P0445 Evaporative Emission System Purge Control Valve Circuit Shorted 45
P0446 Evaporative Emission System Vent Control Circuit -
P0447 Evaporative Emission System Vent Control Circuit Open -
P0448 Evaporative Emission System Vent Control Circuit Shorted -
P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance -
P0452 Evaporative Emission System Pressure Sensor/Switch Low
P0453 Evaporative Emission System Pressure Sensor/Switch High -
P0455 Evaporative Emission System Leak Detected (large leak) -
P0456 Evaporative Emission System Leak Detected (very small leak) -
P0461 Fuel Level Sensor “A” Circuit Range/Performance 47
P0462 Fuel Level Sensor “A” Circuit Low 47
P0463 Fuel Level Sensor “A” Circuit High 47
P0500 Vehicle Speed Sensor “A” 50
P0506 Idle Air Control System RPM Lower Than Expected 51
P0507 Idle Air Control System RPM Higher Than Expected 51
P0562 System Voltage Low 53
P0563 System Voltage High 53
P0601 Watchdog 56
P0606 Checksum 56
P0610 Variant Code not Programmed 57
P0628 Fuel Pump Control Circuit Low 59
P0629 Fuel Pump Control Circuit High 59
P0630 VIN not Programmed or Incompatible 60
P0638 Throttle Control Error 61
P0661 Intake Manifold Tuning Valve Control Circuit Low 63
P0662 Intake Manifold Tuning Valve Control Circuit High 63
P1301 Misfire level causing emissions increase 67
P1302 Misfire level causing catalyst system damage 67
P2100 Throttle Actuator Control Motor Circuit/Open 69
P2102 Throttle Actuator Control Motor Circuit Low 69
P2103 Throttle Actuator Control Motor Circuit High 69
P2104 Throttle Actuator Control System – Forced Idle 70
P2105 Throttle Actuator Control System – Forced Engine Shutdown 70
P2106 Throttle Actuator Control System – Forced Limited Power 71
P2107 Throttle Actuator Control Module Processor 71
P2108 Throttle Actuator Control Module Performance 72
P2122 Throttle/Pedal Position Sensor/Switch "D" Circuit Low 72
P2123 Throttle/Pedal Position Sensor/Switch "D" Circuit High 73
P2127 Throttle/Pedal Position Sensor/Switch "E" Circuit Low 73
P2128 Throttle/Pedal Position Sensor/Switch "E" Circuit High 74
P2135 Voltage Correlation Error (Sensors “A” & “B”). 74
P2138 Voltage Correlation Error (Sensors “D” & “E”). 75
P2173 Throttle Actuator Control System – High Airflow Detected
Non-MIL Fault codes
P0480 Fan 1 Control Circuit 49
P0481 Fan 2 Control Circuit 49
P0537 A/C Evaporator Temperature Sensor Circuit Low 52
P0538 A/C Evaporator Temperature Sensor Circuit High 52
P0564 Cruise Control Multi-function Input Signal 54
P0571 Brake Switch “A” Circuit 54
P0578 Cruise Control Multi-Function Input “A” Circuit Stuck 54
P0616 Starter Relay Circuit Low 58
P0617 Starter Relay Circuit High 58
P0646 A/C Clutch Relay Control Circuit Low 62
P0647 A/C Clutch Relay Control Circuit High 62
P0806 Clutch Position Sensor Circuit Range/Performance 64
P0807 Clutch Position Sensor Circuit Low 64
P0808 Clutch Position Sensor Circuit High 64
P1113 Air Intake Control Valve Circuit 66
P2602 Coolant Pump Control Circuit Low 68
P2603 Coolant Pump Control Circuit High 68
P2612 A/C Refrigerant Distribution Valve Control Circuit Low 76
P2613 A/C Refrigerant Distribution Valve Control Circuit High 76
B1422 A/C Compressor Lock Sensor Circuit 77
U0101 Lost Communications with TCM 78
U0122 Lost Communications with VDCM 78
U0127 Lost Communications with TPMS 78
U0316 Software Incompatible with VDCM 79
Discussion Starter #2
Here (att) is the "Service Notes" document. I seem to only have the 2009 version of the whole thing. Other links were dead so attaching.
1 - 2 of 2 Posts
