Really. What idiot put the rear fuse panel in such a position that some of the fuses (the ones on the bottom left) aren't visible, the panel is too far away to access them, and you can barely get one finger to touch the fuse (with much body contortion).
My AC gave up, first thing is to check the fuse. Not remotely possible without removing the entire rear inside body panel. That fuse is in the bottom left row, can barely touch the thing. Use a needle nose plier blind? Probably short some other fuses. WTF??
It would have been a simple matter to place the panel in a reasonable position, but simple access and reasonable are foreign terms to Lotus. Any suggestions, other than getting something from Germany or Italy?
