Do you have a picture??I have one, but it is damaged. The leading point of the lens is cracked, the lens also has a scrape that should buff out.
I haven't researched all of it yet but I'm keeping your comment readily available and will reference it during the job to assist as necessarybigbird06815, I assume you will be tapping into the right turn signal wire to wire in your new 30 LED DRL turn signal. So, on the left side, you could try to pop the left turn signal feed wire's pin out of the headlight plug and then use that to power the new matching left side turn signal. (If you can't get it to release, I guess could cut it instead.)
