1 - 6 of 6 Posts
Evora '10
Searched but no clear engine mount torque spec. See question posted a lot. Looking for Passenger side engine mount torque specs, any actual reference out there? Manuals sorta show for 2nd generation mounts but a different mount from S1. The 2009 manual has no reference.
Evora '10
Close... I believe #23 is for the S2 style mount. I have the earlier, 2010, S1 engine mount. That is what I'm trying to find. There are ~5 bolts to the engine block. Fortunately you can get the other mount torques from this reference.
Evora '10
Bumping to still seeing if anyone has the S1 RH mount torque specs. This one...
1262904
I did find the S2 mount torques in an Exige service manual (section TDP) and similar reference in Evora Service manual B132T0327D/12/07, July 2012 (same torque numbers). Reasonable to map these over to S1 I guess. The insulator to subframe is 47NM (not mentioned in this diagram)
1262898
For completeness, the Toyota No1 Engine mount bracket RH, the Toyota 2GR-FE manual shows below. Found in the Toyota 2GR FE 1000 page service manual (AVTO 0566 pdf - sienna or camry) which has everything about the engine.
1262903
That's totally reasonable and I've done it similar estimation often. You can also reason about what torque is appropriate from the fastener. I do it often, but I'm not qualified to give recommendations.
donour
1 - 6 of 6 Posts
