1 - 14 of 14 Posts
I searched and surprisingly didn't find an answer. Will the 19/20 "Lotus Design" wheels from an Evora S fit a newer 2017 Evora 400? Obviously they are the right size (19/20) to clear the bigger brake calipers, but I am wondering if anyone knows about the offset. Thanks in advance.
Thanks so much chrome orange!! The "Lotus Design" wheels were gold/bronze and came on the limited run GP edition Evora S, but if they are the same spec as Option 1 or Option 2 you posted above, it looks like they should fit fine. 8/9.5 with an offset of 52/69 or 55/69 is damn near the same as the 400 wheel spec.
Also, I found this useful wikipedia link that has info on all Evora wheels, it doesn't list offset but is a useful lookup nonetheless.
https://wiki.seloc.org/a/Wheels_and_tyres_-_Evora
If they’re the GP wheels (bronze) then they’re the same wheels as the silver diamond cut and black ones that where on the S1 S’s.
So somewhat related, and I think I know the answer, but the 19/20 rims from a 2013 S should bolt right up on a 2011 NA that came with the 18/19 rims, correct? I read somewhere that the rims from the 400s wont swap out with the S1 rims, but I was pretty sure that all S1 rims were interchangeable.
Correct. I purchased the Design Diamond Cut wheels (19/20) off of a new 2012 Evora S and bolted right on my 2011 N.A.
Not sure about the later NAs, but the early ones had 18/19 wheels, which likely won't fit over the 400/GT rotors since they all came with 19/20s.
MY 13 N/A wheels DID NOT fit my 400.
Said individual apparently doesn't understand the difference between a 18/19 setup and a 19/20 setup. Disregard.
Different offset = sub-optimal suspension behavior
The offset is identical at the rear and has 3mm of extra poke the front. Hardly a huge difference. The 18/19 forged wheels pictured are also as light if not lighter than most of the 19/20s.
1 - 14 of 14 Posts
