Evora Weights
2013 Factory figures:
Base 6-sp NA Base: 1383 kg … 3049 lbs
Fully optioned 6-sp NA: 1431 kg … 3155 lbs
IPS NA: 1436 kg … 3166 lbs
6-sp S: 1437 kg … 3168 lbs
IPS S: 1442 kg … 3179 lbs
Thus:
Option Packs add ~ 106 lbs
IPS transmission adds ~ 11 lbs this includes additions do to oil Cooler
S adds ~ 13 lbs this includes additions due to SC and Oil Cooler and reductions due to flywheel
Most of S weight comes from the option packs not the supercharger itself.
My fully optioned S just scaled in at 3130 lbs with headers, cat replacement, CAI, w/oil (extra 2 qts, 3.2 lbs) and 10 gals fuel 5/8 tank (35 lbs under), OEM battery; full tank would give 3165 lbs or 3162 lbs with standard capacity oil pan. Figuring 5 lbs saved with headers & CAI & 1 lb with Oil Cooler mods puts it back to 3168 ~ orginal pre-mod weight (same as Lotus claim). So while it is a fat pig, at least Lotus gives honest weights. Final PWR: 8.1 lbs/Hp
My corner weights for 3130 case: LF 592, RF 625, LR 964, RR 949
--- Front ratio 38.9%, Rear ratio 61.1%, LF-RR ratio 49.2%, RF-LR ratio 50.8%
* Spreadsheet Link *
Evora Weights
Thus:
Evora Weights
