1 - 17 of 17 Posts
Hey guys, I picked up a 2007 Exige that is heavily modded. Came with just the key, no fob. I don't have manual to get the pin for the car but the other issue is it has an AIM dash. Is it still possible to programming a new for to the car? If so how would I go about it? Thank you!
If there is no fob, the immobilizer has been bypassed and your car is as easy to steal as a 73 Chevy. Break the column lock and drive away.
You can get the code from the dealer.
figure out if there is still an immobilizer in it, or if it has been torn out
Also I don't believe my car still has the Cobra alarm system. I would just like to be able to lock and unlock the car when parking it.
There is no immobilizer in the car. Considering I don't have to use a fob to start the car as it sits. Just hoping to be able to lock and unlock when taking it out and about.
I have not had to dig into mine, but I have purchased and programmed remotes. So call the dealer and get the code and buy a Cobra remote and you can follow the directions elsewhere on this site
6.94915254 lbs/hp
His battery will also last longer than a week without dying lol!
Why? What’s it got to do with his issue? All you seem to do is be a Debbie Downer when you post
see #11
Sounds like this “excuse me”….
Get something such as a Stebel Nautilus. Or, from beloved parts supplier, RD Enterprises: Compact Air Horn $59
Ultra Compact two-tone air horn unit measures about 4-3/8" tall x 5" long x 3" wide and weighs under 2 lbs., and it's LOUD! The sound measured at 2 meters is 115 dB. Easy installation because there's only one part to install, horn compressor relay and instructions included.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
These (lube, mods) make a huge change in shifting. I also reoriented one swivel joint.
7. Rear toe-links can loosen and break with disastrous results. You can check tq periodically, or use Nordlock washers. Best is conversion to better engineered brace, such as BOE’s and InoKinetic’s for two examples.
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
18. Many benefits to joining Lotus Ltd (USA Lotus club). Get help wherever you are, using the contact booklet they update every year. (I’ve helped a few ppl who contacted me.) This is who stages LOGs (Lotus Owner Gatherings) every year. https://lotusltd.com
Plus, “How to bleed brakes”:
Maintenance and Repairs.
How to Search:
Lol just post a link. He joined in 2009. I don't think he needs all that, and it clutters up threads.
07 Aspen White Exige S - MT
Cause it’s more interesting to see how he made 700HP but can’t program a key fob? I’m the troll under the bridge I guess....700+ HP is a huge number on these, I’d love to see that setup, or not just 1, but owning 2 exiges in excess of 600HP.
I’d be more concerned with learning how to fix your own idle issues before exploring 700hp cars, or trying to troll.
just add a manual battery by-pass switch and hide it somewhere in the cabin or trunk. better security and more reliable than the OEM cobra alarm system
You must be mentally ill, as you’ll see the issue im having is a common issue that hasn’t been resolved in 14 years correctly unless going to a standalone. I have no desire to have a 700hp Exige, but sure like to see what people are capable of with these cars. And I could throw this right back in your face as looking back at your “helpful” comments are just about as worthless as can be. So enjoy your day buddy, and I’ll be sure to fix my idle issue, as i actually try and help issues get resolved and contribute my experience and knowledge to the forum as well as look for others who are more knowledgeable to help me along my journey as I don’t have the luxury as most of taking my car to a shop sh*tting money out at them to fix it.
Check out this link if you want to add keyless locks back to your car without the alarm/immobilizer.
2007 Phantom Black Exige S
Must be the Covid getting to us. o_O
Both of you have been very helpful to others on this forum. I hope this continues...
1 - 17 of 17 Posts
