Sorry, you've failed the Exige ownership test...please turn in your keys.
As Shinoo stated, it should unscrew like a regular bolt. Left or Counterclockwise to get it removed. Someone may have screwed it too hard to the right or clockwise, thereby stripping the threads. If it just spins, then that is the case and you may have to get slightly medieval on it.
The car should roll on it's side not roll back. Are you sure you are talking about the same plastic screw in the front grill that everyone else is talking about?...I put enough pressure on it that the car will roll back...
Mine doesn't even turn - it's to the point where if I try any harder, I'll strip the plastic head. I put enough pressure on it that the car will roll back if I don't have the e-brake on. I tried this about 2 weeks ago when I first took delivery of the car and when I first looked at it, thought it would be a piece of cake.
:no: Not a good idea - they are light weight and easy to bend.The tow hook is made of ordinary steel and is full of rust. This is the reason why the plastig screw is stuck.
My hook started to rust all over and I could't remove the plastic screw (it got destroyd).
I removet the tow hook completly. If I need to tow the car I'll use one of the wishbones.
You also fail the Lotus Owner Qualification test. Read your manual.The tow hook is made of ordinary steel and is full of rust. This is the reason why the plastig screw is stuck.
If you have looked at how the tow hook is conected/fastebed to the front crash structure (4 pieces of bolts to the glas fiber structure), I think it's better to use the wishbones to tow the car and I don't meen along the road but onto the rescue car/road help:no: Not a good idea - they are light weight and easy to bend.
