1 - 12 of 12 Posts
I have wanted to improve the aero of my Exige for some time and have been evaluating aftermarket solutions. However, I cannot reduce the front clearance by lowering the car or installing a full splitter because my car just barely makes it into and out of my driveway (and scrapes if my line of approach is off by less than one foot).
So, I fabricated a solution that is a functional compromise: a flat panel that seals the cavity under the backside of the OEM air dam and extends back to fill in the chassis gaps at the front wheel wells. It flattens the entire front underside and modestly expands the "real estate" at the front wheel wells for air to smoothly travel over toward the rear of the car.
I made a template of cardboard using the OEM air dam bottom edge and the OEM aluminum service panel as guides for shapes and fastener locations. I trial fitted the cardboard template several times to finesse design and fit, and then I cut out the aero panel using 1/8 inch ABS plastic ($50 for a 4 x 8 ft. sheet sourced locally here in SoCal). An assortment of screws, nylon spacers, speed nuts and nylox nuts cost me about $15.
The aero panel tucks into the full width of the OEM air dam about 1/2 inch, extends back to cover the same area as the OEM aluminum service panel, and has two extensions that cover the chassis openings at the front wheel wells.
I installed the aero panel with the smooth (shiny) side facing the air flow / ground. The aero panel piggybacks on the OEM aluminum service panel and attaches through the OEM service panel into the OEM attachment points. The aero panel's wheel well extensions are fastened in place with screws and speed nuts that clamp against frame flanges on both sides of the chassis wheel well openings. For two areas of the clam underside and OEM service panel where height differences exist for attachment points, I used 1/4 inch thick nylon spacers held in place on the screws with circlips. The circlips serve to retain the spacer on the screws while installing and removing the aero panel.
Fitment of the aero panel is the same as the OEM service panel but with two extra steps: position the aero panel into place into the OEM air dam and ahead of the front clam at the wheel wells; attach the clips that fix the aero panel extensions at the wheel wells (easy to do with wheels in place once the aero panel is finished and clips are fitted).
Because the 1/8 inch thick aero panel adds extra stiffness to the front underside...which I don't consider to be a good thing, I intend to swap the metal fasteners for plastic ones as a precaution to avoid compounding damage to the front crash structure and clam in the event of a low speed bump.
I took the car out on a test drive today and drove a familiar route at speeds of 55 to 75 mph, including several high speed sweepers, and with short bursts up to 90 mph. While I am no engineer and did not take any before and after measurements using aero instruments, the front end felt more planted as speeds increased and it felt like the front tires had much better bite in corners. This test drive was using Toyo T1Rs that I run on the street, and air temps were significantly cooler than the last several times I drove the same route (55 degrees compared to 75-90 degrees, which means the tire rubber should have less grip than when ambient temperature is 20-40 degrees hotter).
The real test of any aero benefit of my aero panel would be on a high speed sweeper such as Riverside at Buttonwillow or the Roval banked turns at Auto Club Speedway...hopefully soon!
Satisfied that front aero has been improved, I plan to close the gaps around the rear wheel wells by installing Really Light Stuff's rear Undertray Aero Kit. The Undertray Aero Kit's two piece (per side) design looks well thought out for easy removal and installation of the diffuser and engine service panel, and it will clean airflow around the rear wheel wells and to the diffuser. My car runs a BOE Silent Touch exiting above the diffuser, and I already fabricated an aluminum fill panel for the diffuser to clean up the OEM diffuser.
Wonder if you could just replace the aluminum undertray panel with this and have a net zero weight change. How structural is the stock piece? Hmm... ;)
I considered that and concluded that it would not work on an Exige (can't say for an Elise...never seen the front underside of one...but should be similar):
- The OEM aluminum panel is not flat and has bends that are shaped like the underside of the clam so that it can slip under the clam for attachment.
- The aero panel fits over (instead of under) the clam, extends forward into the OEM air dam, and uses the clam fastener holes to fasten to the three OEM speed nuts located on the front of the OEM aluminum panel.
- As far as I know, the OEM aluminum undertray is not structural. It provides some rigidity for the underside of the clam by tying it to the crash structure and chassis. The OEM panel will fold up in a crash (check out pictures of toasted Lotuses).
- If you eliminate the OEM aluminum panel (and the speednuts attached to the front three holes), you'll have to find a way to attach the aero panel directly to the clam attachment holes. Finding a fastener that would work should not be too difficult, and it would eliminate the OEM aluminum panel and offset some of the weight gained from the ABS panel. I may do this for Aero Panel 2.0.
Planning to sell or share your template?
HKFEVER, I didn't make a new pattern of the ABS aero panel after finishing it, and the finalized aero panel now fitted on my car dffers slightly from the cardboard mock up that I made.
- The best way to make a pattern is to start with a couple of large cardboard panels. Use the OEM aluminum undertray to trace out the back part of the pattern onto one piece of cardboard.
- Use the second piece of cardboard to trace the shape of the underside of the OEM air dam.
- Once sure that both patterns are the proper shapes, position them into place on the car's underside (use masking tape to hold into position) and tape the two pattern together where they overlap.
- You could then double cut the overlapping cardboard pieces so that the entire aero panel would be only one cardboard ply thick.
I wish I had a jack or shop that could allow me to do the measurement :(
I can make a paper template of it the next time I have the aero panel off the car. That might be sooner than later.
I may add a 1 inch tall "fence" along the wheel weel extensions and around the front of the wheel wells to channel incoming air.
I know this is an old thread. Would you have any photos of the underside attached to the car. Also interested in detailed photos of some attachment hardware.
1 - 12 of 12 Posts
