HmmmThe new Lotus motorsport exige will have 300hp while the street version detuned to 260hp. A guy on an Italian BBS just went to lotus to see the new cars.
From a heat and packaging standpoint, a supercharger would make more sense than a turbo, AFAIK. Besides, we want the low end power.Randy Chase said:I hear rumors of a supercharger.![]()
It's difficult to scale up the performance of a smaller engine, given the same configuration. As the displacement scales up, the piston stroke gets longer and peak piston speeds go up. As the piston speed goes up, the forces generated on the rod journals, crank journals and crank main bearings go up geometrically.scot said:... Almost doubling the displacement, slightly higher compression ratio, adding in vvti and you should easily be able to double the bikes hp NA. ...
Scot
