1 - 3 of 3 Posts
Hi Guys, just want to know Exige S 2007 wheel spec, offset, P.C.D.
I'm looking for custom wheel to fit front 235/40-17 and rear 275 or 265/35-18, just like Elise race car by Hypersport.
What wheel offset should it be? Don't worry on power and ride height. I got Komotec 280 HP behind my shoulder and Bilstien height adjustable damper.
Regards/Chale
I like the way you think Chale!
Go wide is good....you need more tread since you have the Komotec SC.
The 2007 Exige wheels sizes are different than the S240 and newer models. The matte black wheels that came with the '07 Exige S are in fact wider 0.5 inch wider both front and back on the width.
Bolt Pattern: 4x100
Fronts: 16x6.5 ET31 13.35lbs
Rears : 17x7.5 ET38 16.10lbs
You don't want to go too wide on the rear if your fronts are widen only moderately. Otherwise, you would create a severe oversteer with your handling.
Best of luck and I demand to see pictures once you have achieved the look that your aiming for. :wave:
Regards/Chale
1 - 3 of 3 Posts
