1 - 15 of 15 Posts
Hello all, quick intro: my name is Brandon, and I just (finally....long story/saga) picked up a new to me 2007 Exige S/Starlight Black with a little over 13k Miles.
I drove it home from Las Vegas after trading in my 2005 Porsche 997 C2S (going to miss that car forever I think). I thought I would enjoy the stares and attention it gets but even after a 6 hour drive I’m shocked at the level.
People waking up passengers in other cars to look, people taking pictures, entire gas stations stopping everything to watch you pull in, pictures etc etc.
It’s all pretty surreal at the moment but wanted to officially say hello and add a few pics.
Scott M
Welcome and congrats!
Your experience of passersby is the norm. Doesn't seem to matter what model Lotus, folks have an urge to check them out. Heck, I have a grumpy "friend" who sold his V8 Esprit because he couldn't live with the attention it received.
These are brilliant cars and you will be very happy, albeit a tad too young to drive.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Stock: “Excuse me”
5. Transmission:
And, use:
How to Search:
Thanks gents, much appreciated!
Congrats!!! I had my eye on this car as well.
Your car looks great! I'd take a picture too if I were to see you drive by.
Congrats, beautiful car. The Elise garners a ton of attention, the Exige so much more so.
Congrats on the purchase! Very nice Exige. The attention it gets will never get old. Just has such a special and unique look to it all. Enjoy and drive safe!
Nice! Just brought home an Elise to SLC myself. If never had your Porsche out at UMC, and even if you did, definitely find some time to get your Exige out there.
I took a visit to that dealer earlier this year. I was drooling over your Exige fore sale. Looks awesome man!
How did you like the drive compared to the Porsche?
Did you take a look at the Noble?
Discussion Starter · #11 ·
Just came back from my first proper drive.
Oh. My. God! I feel a connection to my Porsche still and don’t want to disrespect it, but not even the same experience at all. Wow.
I actually did check out the Noble but it’s another extreme even beyond the Exige as far as parts access/info. Looked cool but Exige has always been a fav of mine just looks alone.
Hey there fellow SLCer! Brought an Elise to SLC this spring after purchase from a LotusTalk member. If you haven't been on a track yet, definitely try to get out there (Utah Motorsports Campus, fka Larry Miller Raceway).
Best color! Congrats!!!
1 - 15 of 15 Posts
