1 - 11 of 11 Posts
The title says it all. Comparing a 08 Exige S 240 vs an 07 Exige S, since the 07 has an intercooler.
:huh:. They both have an intercooler and the same engine but different tunes.
Unless you are talking about the Exige A 240, then I haven't a clue.
From what I understand, the S 240 is the same (engine wise) as the '07 "S" other than a more aggresive ecu tune. Therefore, unless you care about launch control or the other minor changes (listed elsewhere on this forum), you'd be better off gettin a used '07 (I'm guessing that's why you're asking...you're contemplating a purchase?) and having Charliex or ForcedFed due their own tune/ upgrades. You'd end up with more power and probably more money in your pocket when it was all said and done.
s240 has bigger injectors, beefier clutch, larger brakes(4pistons in the front), variable TC, launch control... if you are gonna go for an aftermarket SC/Turbo setup tho I would skip even the 07 and go for an 06
Did someone say 06...anyone anyone...Bueller Bueller?
:panic:
I usually upgrade to the new models, haven't seen a lot in the 08 that makes me want to trade in the 07, powerwise i'm pretty happy there too, though i would like to stop a bit quicker, but that alone isn't worth the 30-20K or so trade in depreciation.
^^^ +1
However, if Lotus comes out with a more HP Exige for '09 around the 260 mark then it might be worth it. ;)
Charlie, would you be able to squeeze anymore HP out of the 240 than an 07 Exige S with an ECU tune? Assuming I would be going with the Gotham 265, should I just go with an 07 Exige S, considering only HP and not the other changes/upgrades in the 08 S 240? Thanks!
i cant see why the 08 240 would get more hp than the 07, the 240 should be able to take the same upgrades as the 07 does and vice versa.
1 - 11 of 11 Posts
