1 - 3 of 3 Posts
Hi!
I had previously a CEL which went away after a while.
I was finally able to read the code today and it was
P0463 Fuel level sensor circuit high input.
Does this mean that I had overfilled the car with petrol, or does it mean something else?
its possible an overfill could cause it i suppose, the code gets set when the ecu thinks that fuel wasn't used when it should have been, either that or there was a bad connection.
Ok!
Thanks. Seems like I just can delete the code and assume that it won't return unless I overfill the car. And if it does occur I need to start checking some connections.
Cheers
1 - 3 of 3 Posts
