Instead of the full treatment, costing
approximately $950, can only the front
clam portion be covered and if so at what
cost?
cost?
I had no trouble applying normal wax by hand. You do want to make an effort to not rub the wax across the edge of the StarShield (at right angles), but make sure that you wipe/rub along the edge of the film (parallel to the edge) - similar to how you wax along the pin stripe tape on many other cars.Ridgemanron said:I'm assuming a spray applied wax
will be best to use and am only a bit
concerned with where the edges of the film end.
