I have changed or inspected all the bulbs and I'm still getting the fast flash using the left turn signal. Ideas?
Thanks
Aaron
Are you getting a fast flash and the bulb is blinking, or is the bulb not blinking?
I had a similar problem 2 days ago with fast flash and no blink. I took bulb out and it looked good. Then I cleaned contacts, as stated above, reinserted, and all was good.
If you can confirm that bulb is good, use a tester to check if you have voltage on the back side ofthe socket. Could be a loose connection. If not, start tracing for a short.
