Yikes. How did this happen?
Narrow winding road + High concrete curb + Wet leaves. I wasn't even goofing around, honest. I was following traffic around a left hand bend in my neighborhood when all of a sudden the steering went light as the front wheels lost grip. I don't recall even having time to complete a thought before the back end followed and I drifted right up into the curb.Randy Chase said:Yikes. How did this happen?
I suspect that Stan is wondering if the joint was beginning to fatigue and fail on it's own. In any case, this could be a good excuse to replace the tie-rot end with the double shear brace instead...Yes, take close up pictures...Stan said:If possible, get some extreme closeups of the link and joint ends at the break.
Yup, won't hurt to take a peek. So far, we can see that the threaded portion of the joint bent. I'd wonder about the outer joint too, and other bits. Even if everything appears to check out, the alignment rack may indicate change. Maybe you already have a baseline alignment...perhaps related to the rack job.TimMullen said:I suspect that Stan is wondering if the joint was beginning to fatigue and fail on it's own. In any case, this could be a good excuse to replace the tie-rot end with the double shear brace instead...Yes, take close up pictures...
If nothing else is bent or broken (A-arms, etc.) I wouldn't expect that the CV joint would have problems - it is intended to be a steerable joint from a front wheel drive car, so it should have a large range of motion - it just went suddenly to full turn.andykeck said:Beyond the a-arms, I'm concerned about the CV joint as the rear wheel had a pretty good range of motion forward that the joint may not have been able to take.
Actually this is a good point. With a non-repairable chassis, it is better for the suspension to "fail" in things like this. A similar case is the old Lotus Elan. The stock front A-arms are fairly fragile. But when the corner gets hit, the a-arms bend and are destroyed. But the non-repairable (mostly) pivot points on the chassis usually survive. Other's have installed "racing" reinforced A-arms, that survive the crash - but the chassis doesn't...:shrug:I considered telling the dealer to add the brace and I guess I still have the option, but I'm not likely to have them do that. Two reasons. <...> Second, I don't believe that the brace would have done much good with this big an impact and maybe would have spread the damage elsewhere.
Hi, I just bought an Elise a month ago and have been reading the posts. Was this failure due to the weak link in the rear suspension as brought up by Stan and then also discussed under the heading of safety recall by Ronin and Tim? Should I be concerned?andykeck said:Just in case anyone was wondering, the Elise does not handle better when the rear wheels are allowed to independently steer themselves. I guess holding rear toe constant is a good idea after all.![]()
No and No:wave:big guy said:Hi, I just bought an Elise a month ago and have been reading the posts. Was this failure due to the weak link in the rear suspension as brought up by Stan and then also discussed under the heading of safety recall by Ronin and Tim? Should I be concerned?
Andy made contact and then it broke:tadts:andykeck said:Narrow winding road + High concrete curb + Wet leaves. I wasn't even goofing around, honest. I was following traffic around a left hand bend in my neighborhood when all of a sudden the steering went light as the front wheels lost grip. I don't recall even having time to complete a thought before the back end followed and I drifted right up into the curb.
There is debate about how critical this known weakness is. Many would argue that the issue is almost exclusively limited to those who track their cars with stickier than normal rubber. I could not find examples if this failure occuring on street or light-track use cars either here or on SELOC. In my specific case, something had to give. I hit the curb quite hard. I'd rather break a relatively inexpensive toe link as compared to damage to the subframe or the rest of the suspension.big guy said:Hi, I just bought an Elise a month ago and have been reading the posts. Was this failure due to the weak link in the rear suspension as brought up by Stan and then also discussed under the heading of safety recall by Ronin and Tim? Should I be concerned?
Probably so. One way or another, all the braces in the world won't help if you're the kind of idiot that drives into concrete curbs. (imagine sad nanner here)Patricko said:I would think that the failure that the brace prevents is of the other side on the link. The bit that attaches to the rear sub frame...
**** happens...at least you still have a car:sad:andykeck said:Probably so. One way or another, all the braces in the world won't help if you're the kind of idiot that drives into concrete curbs. (imagine sad nanner here)
Good point. Although I did not enjoy the bus ride of shame this morning.:sad:Patricko said:**** happens...at least you still have a car:sad:
