1 - 14 of 14 Posts
Hello Peeps!
I autocrossed friends Super 7s and Elans years ago. Always had a fond spot for Lotus! Own 6 different TVRs (started when I realised I would never be able to afford a Cobra)
Been friends with Randy Chase for years and went up against him autocrossing my TVR 3000s versus his MR2 (pre Lotus days)
Anyway, got back into autocrossing having a go in a Pontiac GXP coupe.. doing fine locally.. but realised I needed some "other quirky car" to have a better shot and the Lotus fit the bill.
Thanks to Randy for support and info! I'm sure I'll be gleaning more info from him, the site, and others!
That's the best color too :D
Reactions: 6TVRs+
Good for you. These are brilliant cars.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
PS: Friend is a TVR fan.
Has about 6 or so.
One stock.
One with Supra turbo engine.
And....one where he widened the chassis body and stuffed a TT Corvette V8 in it!
Discussion Starter · #7 ·
I had to chuckle as I realised talking to someone recently that the Lotus is the most "common" car in my garage! Lol..
The Lotus... 1 of 2500 or so in 2005?
None of the ones below are broken out by color... just total models made.
Gxp coupe 5 spd manual.. 1266 coupes.. Turbo manuals..1 of 270
77 TVR Turbo Taimar ... 63 Turbos, only 3 LHD.. this is 1 0f 30 Taimars, and was the 1977 NYC auto show car.
68 TVR Tuscan LWB SE V8 .. 302 powered and 1 of 48 in 4 years
79 TVR 3000S ... 1 of 254 in 2 years
72 TVR 2500... 1 of @ 950... and @ 105 of those with this "hybrid" chassis combo. This has a 302 in it also.
But I really am looking forward to time in the Elise!
Can I have a TVR? Kindergarten rules apply here...sharing is caring ;P
Welcome to the forums and congrats on the new Elise. Thanks for sharing the pics of your wonderful collection!
Reactions: 6TVRs+
** The Enforcer **
I'd seen this thread, but I completely missed you were local. The Elise is certainly not common, even here, but considering your attraction to the TVRs (which are obviously fairly exclusive), I'm wondering why you didn't consider an Exige? I don't think I've ever seen a TVR in person, and obviously you have a few. PM if you'd like to chat. Thanks.
San
Discussion Starter · #10 ·
San
I wanted something that would be autocross competitive without much modification... if I want to start spending significant money on mods I have several TVRs I feel I "owe" it to first....lol. Plus, I didn't think the Exige would be as competitive where it is classed...
My Dad just passed away Sunday night and am getting things settled, at some point would love to chat up TVRs or the like...
Bill
** The Enforcer **
Bill
I'm very sorry to hear of your loss. You have the forum's condolences. If there's anything we can do, please don't hesitate to ask. I wish I could say something that would help.
San
Congrats on the purchase! You have a wonderful collection of cars. Also, my condolences to you and your family. If you ever need to clear your head, a nice top down drive in your "new" Elise helps. Enjoy and drive safe!
Gabe
1 - 14 of 14 Posts
