Kind of like this?rotflI have a Rand McNally fully manual GPS.rotfl Lightweight, takes up almost no space at all.
I've been thinking of doing this exact thing but wasn't sure how it would work. Glad to see that it does. I know what I'm doing later todayHere's my solution. Even with the plastic disk, the suction cup lost grip a couple times in the winter but a rubber bumper wedged between the mounting arm and the top of the bottom tray lip has solved that; you can vaguely see the translucent bumper in the second picture.
The way I sit, I see traffic, pedestrians, etc. under the mirror. The Nuvi, mounted on the mirror blocks very little for me that is not already blocked by the mirror and sun visors. And as you can see from the picture, I still have full view out the back. Unfortunately, the mirror ball joint is not strong enough to hold the mirror with the extra weight.Do they not have pedestrians in Kansas City? Does the existing mirror not block enough of your view, that you had to block some more of it? Do you not make right turns on streets that have crosswalks?
That's unsafe, and if I were a cop I would write you up for it. Those things shouldn't be mounted anywhere near eye level.
That said, I use mine for a snow shovel.
Edit: Yes, mount it somewhere on the dash.
I like this one! But it looks like your mount has an extra hinge compared to mine. My mount looks like it will angle down slightly. And I am still not seeing your rubber bumper.Here's my solution. Even with the plastic disk, the suction cup lost grip a couple times in the winter but a rubber bumper wedged between the mounting arm and the top of the bottom tray lip has solved that; you can vaguely see the translucent bumper in the second picture.
I think I am seeing the bumber. Half inch thick, 3/4 inch diameter? I found this mount on Garmin's web site for just under $30. Does that look more like what you have?Here's my solution. Even with the plastic disk, the suction cup lost grip a couple times in the winter but a rubber bumper wedged between the mounting arm and the top of the bottom tray lip has solved that; you can vaguely see the translucent bumper in the second picture.
No, that still doesn't look right. What model Nuvi do you have? Mine is 265 WT.I think I am seeing the bumber. Half inch thick, 3/4 inch diameter? I found this mount on Garmin's web site for just under $30. Does that look more like what you have?
But you still have something that changes ("moves") in you line of sight - that is fairly dangerous (although all to common).The way I sit, I see traffic, pedestrians, etc. under the mirror. The Nuvi, mounted on the mirror blocks very little for me that is not already blocked by the mirror and sun visors.
OK ... my wife (and daughter) got me this for Father's Day. She has a Honda Odyssey with a seven inch, in dash, GPS system that she thinks is wonderful. I do like it on trips, especially in Tulsa, where they think left exits are cool. In the Elise, I am OK with the flat foldy type, too, but I did carry an older hiking/biking Garmin 76CS with street maps for rare ocassions. It typically sat in the passenger seat when in use.But you still have something that changes ("moves") in you line of sight - that is fairly dangerous (although all to common).
I find it very annoying to be driving down the freeway and notice the car next to me with a display posted half way down the windshield (usually under the mirror) not only blocking a large part of the view out of the windshield, but also producing a bright glare in the driver's eyes at night (heck it's lit up enough that I'm noticing it from the next car). Besides being distracting, it kills your night vision.
If you have to have a GPS, mount it low, out of the line of sight out the windshield. But I'm with Kestrel - I still use the manual, portable, foldaway, flat, Rand McNally type of system.
First dibs on your Micro Mirror if you do!:nanner2:Okay, maybe height is an issue, the mirror is exactly at eye level for me and it's downright unsafe to drive around with a giant blindspot covering the crosswalk when you're turning right. If I'm in Manhattan or something I know I have to duck and look around it because there will inevitably be people in the crosswalk, but I could see myself getting lazy in a place like Kansas City and plowing into some random old lady walking her doggie. I got a Micro Mirror and that solved most of the problem at the expense of some rear visibility, that thing really is micro. I'm thinking about going with what another forum poster did and installing an aftermarket mirror from Mexican Zone that's a slightly more proportional fit for this car. Not to disrespect the awesome build quality of the Micro Mirror.
