1 - 13 of 13 Posts
I've spent a long time looking.
Eventually found the right one for me. To those out there looking don't give up.
Lots of smiles lots of thumbs up and one "Hello Officer" and that's just over one week of ownership.
2008 SC
Looks terrific. Good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Congrats!!! I can still distinctly remember the first time I brought mine home. Definitely can feel that vibe coming from you. Enjoy and drive safe!
Discussion Starter #9 (Edited)
Thanks for the good vibes. I belong to the Lotus Club Canada (Greater Metropolitan Toronto Area) and those guys have been absolutely fantastic. At the first meeting I attended one of the members brought me out in his Elise, after a few min in the car I looked at him and said "I'm in trouble" cause i knew then I had to have one.:grin2:
Congrats! Looks great. It’s my favorite color! I’m located in Toronto/North York, wondering if there is a GTA forum/meets. I’ve owned my 2007 Elise for almost a year. Haven’t seen any Elises around. Thanks, Yuda
Congratulations! I also have a 2008 Elise with the supercharger. I've driven naturally aspirated and supercharged, and for me the supercharger makes a big difference coming from other cars with more torque and horsepower. Plus I'm not skilled enough to drive the Elise consistently at the higher RPMs necessary to make the N/A car sing. I thought my Honda S2000 drove like a go-cart, but even it pales in comparison. You made a great choice with this car. And you're right that waiting for the right one is usually the way to go. I spent 9 months looking before I found one with all the right check options. It's not easy because every year there are less of these puppies to choose from, but there are still enough out there that the odds are high that eventually the one you want will go on the market.
Are you planning any modifications? You can really go crazy once you go down that road. I've added aftermarket Sonic Fury exhaust, two-piece Girodisk rotors, Racetech struts, new radiator, new Inokinetics ShiftR and cables, new Inokinetics sway bar, new engine mounts, tow hooks (front and rear), racing harness with Shroth 4-piece belts, and a bunch of aesthetic improvements. I kind of went nuts, but that's because this is the most fun I've ever had driving a sports car. So enjoy!
1 - 13 of 13 Posts
