I've owned the car 6 days and already I'm starting. I did Stan's shifter bracket mod, though I ended up using a 50mm bolt, 3 washers, and two nuts instead of a spacer.
Anyhow, I am very satisfied with the result. The plastic center console doesn't move around nearly as much when shifting, and I can reliably shift into second from any other gear. Also, I don't think I'll be accidentally putting it into reverse while trying for first like I had done a few times. Accuracy is much much improved. Feel is improved as well. It's not great, but it is light years better. I also sprayed some lube down the reverse/first lockout slide and the horrible squeak went away.
All of the instructions I read involved removing the seats and the center console completely. I was able to do it just by undoing the two bolts on the side of the console, disconnecting the plugs, and swinging it up and out of the way so I didn't need to cut the zip tie on the boot.
Next up is fabricating a mount for two aluminum cup holders I got off of amazon out of aluminum angle. I was thinking of mounting it under the dash in the middle where the two bolts are in the middle. I will post pictures.
