1 - 7 of 7 Posts
Hi Lotus enthusiasts, Canadian member here hoping to educate myself more about the Elise and take my driving to the next level. Owning an Elise has been a very long time dream of mine. Last summer I became the happy owner of a 60th anniversary edition in yellow. Absolutely loving this car!
Welcome! Can’t give any new advice just share what I was advised and followed, you are probably already aware. Double check that the recall from 2007 regarding the oil line was addressed, consider changing the original radiator that tends to break down, keep a distance from other cars, and stay out of other drivers’ blind spots. Cheers.
That looks terrific.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Wow, absolutely amazed by your post. Thanks so much for taking the time to go into so much detail. This has gotta be the holy grail of best advice.
MUCH APPRECIATED !
shay2nak
Congrats!
1 - 7 of 7 Posts
