1 - 6 of 6 Posts
Hi all:
This is a long story so I will give you the short version.
Both headlight assemblies completely fogged up
Dealer said it's normal, or check the drain hole to make sure it's clear.
So the question is, is there REALLY a drain hole in the headlight assembly before I take the tire off and inner fender liner to check?
Thanks
Headlights are not sealed airtight. Temperature/humidity changes can cause fogging.
TADTS.
Fortunately there are easy improvements you can make to eliminate fogging. I posted it somewhere. Search my posts and you'll find it.
1 - 6 of 6 Posts
