1 - 20 of 23 Posts
SOLD: Wicked Street Car/Well Sorted Track Car - 2007 Exige S
2007 Lotus Exige S
This car has seen a fair amount of track use. It is extremely well sorted out for that. It is also a road legal NJ registered road car (Collector Car status), but the racing motor mounts, Nitron GT3 suspension and racing exhaust system make it a loud and stiff ride (for the gear head its pure bliss).
I have built this car to be very fast, reliable and is always a head turner. Maintained with open check book, cost no object with Sports & Specialist Cars (Lotus dealer in Hopewell NJ) doing most of the work. Engine oil, filter, trans oil, front brake pads changed every 4 track days. Never hit anything and no off track events. Even though this car has seen track time, you would be hard pressed to find a better maintained car. I am the second owner and did all the modifications (the first owner rarely drove it when it was stock).
First place winner at LOG 33 (2013) for best Lotus Exige. First place winner at New Hope Auto Show (2011) Specialty Car Class and Honorable Mention Specialty Car Class (2014).
All the interior carpets, sound deadening material and plastic bits that aren’t important are taken out. There are Lotus Sport carpets for driver and passenger wells (new set and used set) that can be screwed in for use so the car looks like a normal Lotus Exige S. No stereo or speakers. Stereo removed for gauges that are important.
This car weights less than 2000 lbs, has more than 280hp at the wheels and does zero to 62mph in less than 3.6 seconds.
Custom build plate identifying this car’s serial number as a Lotus Sport 111RS.
Lotus Sport never made an RS, I did.
The list of Mods is extensive (see below). I do not have the OEM parts that were replaced. This car comes with three sets of RAC Mono wheels, one set is on the car, one set has Yoko slicks on them (used two track days) and one set is new in box and never taken out. I have a number of interior CF parts that have not been installed and are new in box (interior sills, and side dash pods). Included is a brand new engine all built and on an engine stand (with upgraded valves, springs, oil pump gear and larger oil pan), new OEM trans (with LSD) and clutch.
I will not part out. Don’t ask. Approximately 20,100 miles on car/engine/trans.
$60,000 Firm Contact GSchostak at aol dot com (please, if you don't have the resources to buy this car, don't waste my time). Would consider a restored Lotus Elan DHC twin cam as partial trade plus cash.
The car and the modifications
SCCVC11157HL83275 (Storm Titanium) Sticker Price $65,820.00
Carbon Fiber Parts
Prototype Composites Exige 240 roof $2865.00
Reverie 1650mm CF wing & mounts $2177.76
Reverie Rear Diffuser $1100.00
Reverie Exige Front splitter $1400.00
CF interior panels, door, sills, dash panels (HK Fever) $1200.00
Side skirts (HK Fever) $795.00
Marque Mirrors (BOE Fabrication) $409.00
CF Exige rear engine hatch $1500.00
Reverie CF Side Scoops $642.28
RLS Intercooler Heat Shield $235.00
CF exterior panels (HK Fever) $480.00
CF Shift tunnel custom (no Ebrake opening) $650.00
APR CF front Canards $285.00
AC CF Surround (HK Fever) $165.00
Reverie CF shift Knob $259.99
Engine Related Mods
Accusump pre-oiler kit provided by and installed by Lotus $1562.40
Custom oil catch can and valve cover venting system $2000.00
Sector 111 & V2 Custom fuel tank rebuild $650.00
BOE Surge Tank & adjustable fuel pressure regulator $650.00
RLS Intercooler – black $1185.00
RLS Intercooler Tubes – black $225.00
RLS Intercooler Shroud & tubes & side ducts $996.00
2bular Header & Sportcat (Sport CAT is brand new, not used) $1790.00
2bular GT3 8 x 16 exhaust $600.00
2bular test pipe $200.00
Koldfire custom tune & programing cable $1400.00
Chimera Lithium Ion CF Battery & Aluminum mounting bracket $1000.00
MRW Fuel Rail $250.00
Denso 255 fuel pump $275.00
Sector 111 track mounts, racing motor mounts $299.99
RLS Pulley Mk II w/ Tool (smaller pulley for Supercharger) $155.00
Moroso Oil Pan $499.00
High performance airbox & filter $125.00
Radium Engineering silicone intercooler coupler kit $91.16
Brakes
AP Racing Big Brake Kit $6000.00
Stillen Metal Matrix Brake Pads ($223.98 each set – 2 sets) $447.96
Steel braided brake lines $126.16
Suspension
Nitron Triple adjustable shocks $4,995.00
V2 arms $250.00
Sector 111 RTD brace (plus spares) $750.00
Engine Cooling
Aluminum single pass radiator $545.77
Radium Engineering coolant expansion tank $342.00
Silicon radiator hoses $187.00
Interior Mods
Technocraft CF seats $2400.00
Traqdash system with HD video camera interface $1600.00
Personal Steering wheel $260.00
Quick Release Steering wheel mount $638.00
Panovise 8” flex mount for traqmate $38.79
Extension wire for Defi DIN gauges $150.38
Defi DIN gauges (water, oil temp and oil pressure) $640.00
MTX-L digital air/fuel gauge $268.00
Auto Meter Boost gauge #7359 $228.33
Safecraft 5 point harness (new webbing 2014) $800.00
Safecraft black fire extinguisher & seat bracket $369.99
Wheels
Monolite wheels, black (three full sets, one set new in box) $9000.00
Blackwatch racing steel wheel studs and nuts $175.00
Other Parts
Simply Sportscars shift cables $300.00
Sony HD video camera interfaced with Traqmate HD system $400.00
Custom video camera mount for harness bar $280.00
Boomerrang rear tow hook $99.95
Folding front tow hook $86.43
Modquad custom shock reservoir clamps-rear $152.00
Cool Suit ice box and shirt (large) Spare tubing for connection to shirt $400.00
Lotus Shop Manual $350
Lotus indoor black car cover $400
Spare Engine/Trans/Clutch parts
New 2ZZ Toyota Engine with upgraded valves, springs, oil pan & pump gears $7000.00
New OEM 6 speed trans with LSD $4000.00
New Fidanza V2 Clutch $399.00
New Fidanza Flywheel for Exige $395.00
New APR Flywheel Bolt Kit $42.00
Recalls: Oil Line recall performed March 2013
The fine print: The labor cost (which I have not detailed) to install all the custom modifications is so stupid expensive you could buy another car. A number of CF panels for the interior that are new in box. I have all the receipts for everything. This is my third Lotus and second Exige S. I know these cars well.
Here is a video of my car on the street: https://www.youtube.com/watch?v=OQZ5Pq3NVss&list=UUMRCWTBNAbSnyfFvxKy9rbQ
Wow!
What is the plate in the passenger floor?
The grey material is OEM sound deadening material. The bolts are for the Cool Shirt box that the custom mounting plate attaches to. There is a removable connector cable that plugs into a hard wired receptacle that connects to a small black switch on the steering column to turn on/off the motor in the cool shirt box.
Certified WTF?
This car was my Exiges mentor!
Discussion Starter · #9 ·
I'm retiring from the track. It was fun for nine years with three different Lotus' and one Porsche, but time to move on. This Exige is too fast for road use only, which is why I'm selling it. I'm going old school and getting a classic Lotus.
I also have three racing karts that are up for sale. One of them is a Lotus.
Discussion Starter · #11 ·
$6K for the Lotus kart, $5K each for CRG and Zanardi karts.
Super Moderator
Sticky tape...they all have that
I hadn't seen it before (not on my Elise... but it is older) :)
Discussion Starter · #14 ·
Princeton, NJ
Discussion Starter · #15 ·
** The Enforcer **
Very nice car and setup. I have a lot of the same parts. Where did you get the center console without the emergency brake cutout? I have the same brakes, hence my interest.
Nice Lotus cart BTW. GLWS.
San
Discussion Starter · #18 ·
Thanks for the complements. It's a great car and someone will get years worth of work in an instant. No regrets, it's been a lot of fun and great memories.
The CF console was custom made by HK Fever. Only two ever made and I had to buy both to get them produced. Waited 6 months. Sold the other one last year on this site.
Discussion Starter · #19 ·
SOLD. To one very lucky guy.
shay2nak
that was fast!
1 - 20 of 23 Posts
