1 - 18 of 18 Posts
Sold my house just as the pandemic started and bought a dream car, a S260 prepped as a cup car (cage, fire suppression, electrical cut off). I store the car in Alpharetta but live in the city. Hope to connect with some Atlanta Lotus peeps virtually or 6ft apart until track days/cars and coffee resume.
1261661
Welcome! Your Exige is gorgeous!!!
I am also a new Lotus owner and I live just outside Alpharetta. I need to create my own introduction thread.
He's on fire!
Welcome. I'm a current Lotus owner hoping to one day live near Alpharetta :)
Reactions: vrperc
Welcome! Beautiful exige! Evora S owner in Atlanta here. You should join the Lotus LTD southeast Facebook group, sometimes they'll post local lotus events.
Reactions: vrperc
Congrats! I have a S260 FE and an Exige V6 Cup-R that we track quite frequently. If you haven't ran many HPDEs, I would strongly suggest starting at Barber Motorsports. It's an excellent teaching/learning track. Road Atlanta is fun but can be very intimidating if you are a newbie. You also have Atlanta Motorsport Parks which is a fun little roller coaster track.
Take care and Enjoy,
Eldon
Sweet ride. I'm in EAV and used to have an S240 and still have my non-streetable Elise auto-x beast. You should bring it out to a local auto-x (when they happen again) to get an idea of it's chassis dynamics before putting into a wall on track.
Discussion Starter · #8 ·
Thanks man! We should meet up sometime, admire cars from 6ft apart, ha!
Discussion Starter · #9 ·
I’m in cabbagetown, once this all blows over it’s good to know there’s lotus folk so close. Looking forward to seeing your beast at autoX. I’ve been going on some mountain cruises to get a feel for the car and push it a little (without being too stupid), can’t wait to really stretch it’s legs and learn where that limit is!
Discussion Starter · #11 ·
Eldon
Nice line up! Thanks, looking forward to seeing you and your cars at events once things resume...
Discussion Starter · #12 ·
Just got approved today. I’m going to introduce myself there too. Thanks!
Whoa, Cabbagetown. It's a cool place. I can see why you have to store your car elsewhere.
Such a nice car.
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Discussion Starter · #16 ·
Also shoutout to e3 storage! This is my first time using car storage and I spent quite some time researching all the options in the Atlanta area. Couldn't have found a better place to store/wrench on the 260 and hang with other like minded folk. Highly recommend them!
Coolness. I've been curious about a place like this. Can you PM the monthly rent?
Reactions: vrperc
1 - 18 of 18 Posts
