Ok, so I bought a front big brake kit from a fellow member for my 1994 S4 with Toyota brakes. I started to do the teardown of the old parts and after taking the rotors/hubs off, I attempted to pop off the reluctor (abs) rings so I could access the bolts to separate the rotors. The first side wouldn't budge, even after using heat and a puller, so I messed with the other side and it came right off with one tap. After looking at the first side I found that someone had tack-welded the ring to the hub in two small places. I had to grind the welds off to remove it. Has anyone seen this before? I'm wondering if maybe the ring was moving around causing an issue? Also wondering if I can reuse the ring?
