1 - 17 of 17 Posts
How practical is it to leave the front air dam (black piece of rubber) on the bottom of the front end on a final edition esprit model? Do most people take them off? Does anyone know what it is actually called and where is best place to get one if want to add one. I am currently looking at an esprit that does not have one and owner doesn't really know.
I have previously purchased one from SJ Sportcars in the UK for 129 pounds (about $194 plus shipping). This includes the black rubber strip and the fiberglass mounting parts below the spoiler. If all you need is the black rubber strip, I would think SJ would sell it separate.
Cheers,
Alan
The rubber piece is called the "lip spoiler" . It is fastened to the lower valance with 2 other plastic pieces called the spoiler extension panels (left and right hand pieces).
You can get the pieces from SJ in the UK but I would check with JAE in California first.
JAE - Vintage and late model Lotus car parts specialists
It's better to call them than email.
The part #'s are:
lip spoiler A08285501F
spoiler extension panel LH A082B5493K
spoiler extension panel RH A082B5494K
The lip spoiler, AKA ground scraper, is always getting caught on driveways and parking bumpers. Common for them to be broken, missing or just scraped up. You have to be very careful going in and out of driveways. I find by hitting the dips at an angle you scrape less. They are made out of PVC and are 2 pieces, a left and a right. They pop up on E-Bay once-in-a-while. Many owners give up and remove them. They are necessary for the proper aerodynamics but not required for street driving. When they are not on it looks like something is missing, especially if you know they are supposed to be there. When the cars were delivered to the dealers new they were not installed. The dealers had to put them on. Probably because Lotus knew it was too likely they would get damaged by the transporters! Also since they are so prone to damage, they are usually not properly reinstalled, fasteners missing or the wrong ones. Damaged spoilers can be repaired. You can sand and polish out scratches and glue tears back together.
David Teitelbaum
Thank you for the information. I am looking at buying an 02 tomorrow without one and I just think it looks a lot better with one plus like you said, I think it would help with knowing my clearance when it begins to scrape.
I'm guessing there's not one currently available for the 88-93 style? Although I'm sure one from something else could be made to fit. Personally I do like the look of these on several cars, I added an aftermarket one to my STi because it simply didn't look right without it.
That's an interesting idea!
I don't have one on my 1991 - don't think they were used on the early cars - just the V-8's.
I managed to (partially) rip one off of a 2000 V-8 that I has test driving. The dealer was NOT pleased.
I think frankly that they are more trouble than they are worth to install.
Oddly, I also found that just getting new front tires (Toyo Proxies) helped bring my front end up quite a lot.
David Teitelbaum
David,
The later models (02 up I believe) that the OP was asking about is a one piece rubber piece, not the two piece abs one on the earlier cars.
My car sneezes
My front spoiler didn't last one day. So I took the fiberglass pieces off and installed the rubber piece only. I did drive the car for a while with out the front spoiler. I did notice the car felt more stable above 80mph with the spoiler on. Here's a pic of how it is now with just the rubber piece.
My car sneezes
I use the Sport300 blip on my 89 SE
... which is the same as the Sport350, 02+ front spoiler without the fiberglass pieces.
Discussion Starter #15
Thanks for the confirmation on what I kind of figured out from looking at several pics of Esprits. I just bought the lip spoiler on ebay and was planning on doing the same thing by installing it with out the fiberglass extensions. Should give a little more clearance anyway and provide some type of protection to the body.
Discussion Starter #16
Is there any trick to mounting the lip spoiler to the 2002 car without the fiberglass extensions? Do I have to get the mounting hardware from Lotus?
My car sneezes
No trick. The fiberglass piece is sandwiched together between the rubber and the bumper.
1 - 17 of 17 Posts
