Noticed at the track this weekend that there is some seepage around the front caliper bleeder nipples. I noticed this last week at the track as well and ended up tightening the nipple to see if that would cure it, but it's still there. The situation is about the same as detailed here: http://www.lotustalk.com/forums/f91/brake-fluid-leaking-bleeder-valve-after-track-session-72167/
On the passenger side, the fluid is seeping at the base of the nipple. On the driver's side, the rubber cap also has moisture on it, as well as moisture on the base. Has anyone experienced and cured this problem before? I'm thinking about just getting two new nipples, but where can I get them?
