1 - 4 of 4 Posts
I bought the Louvre GTE radiator vents from HethelSport to match my Louvre rear hatch window.
I looked under the How-To section and do not see front clam removal instructions (or if there is an easier way to install these new vents, please share)
Does anyone have front clam removal instructions and/or radiator vents removal & install instructions?
Front clamshell removal/replacement
The clamshell with front access panel may be removed whilst leaving the front bumper in position:
1. Remove both front wheels and wheelarch liners.
2. Open the reservoir access hatch, remove the three screws securing the latch, and disconnect the release cable. Feed the cable through the clamshell grommet. Release the two fixings securing the hydraulic fluid reservoir to the clamshell, and the two screws securing the washer reservoir filler neck. Release the washer tube and harness connector from the washer jet.
3. From within each wheelarch, disconnect the headlamp harness and headlamp washer tubing. Release the two fixings securing the headlamp front mounting bracket to the subframe, and the two fixings securing the headlamp rear bracket to the bumper support bracket. Withdraw the headlamp.
4. From within the front of each wheelarch, release the three fixings securing the clamshell to the top edge of the bumper.
5. From within the back of each wheelarch, release the two fixings securing the clamshell to the top of the 'A' panel, and the single screw to the chassis bracket. Disconnect the side repeater lamp.
6. From the headlamp apertures, release the two nuts at each side, securing the front edge of the clamshell to the mounting rail.
7. Prise out the nose badge taking suitable precautions to avoid paint damage. From the access hole revealed, remove the single fixing securing the clam to the mounting rail.
8. Carefully lift the clamshell from the car and place on a protected surface.
9. Refit in reverse order to removal, noting that all fixing points incorporate provision for adjustment of panel height and alignment via slotted holes or shim washers. The height of the clamshell front fixing rail is adjustable against the subframe at the three slotted fixing points on the rear face, accessible via the headlamp apertures. Clamshell adjustments must be completed before the headlamps are fitted and adjusted to seal correctly against the clamshell apertures.
10. Check headlamp beam alignment.
That's the correct procedure. I recently removed mine to change the clutch master cylinder. Let me know if you have any specific questions.
1 - 4 of 4 Posts
