1 - 20 of 31 Posts
How do you remove Lotus emblem on the front clam?
I bought a black emblem to replace it and it looks like its not just stick on...
do i need to unbolt something behind the clam?
TIA~
Discussion Starter #2
No one?...
The OEM badge has two prongs that help keep the badge straight when putting it on and is held on with two sided tape. So use floss or fishing wire and work it back and forth starting at the top toward the middle. Then the bottom toward the middle
good luck.
Here's how I did it. YMMV.
I used a low power heat gun to get the badge a little hot, then used the finest/thinnest fishing line I could find to floss behind the badge. start from the top and go about 1/2 way down, then do the same from the bottom. Eventually it will work itself free.
Result: way worth it.
Cheers,
-Darryl
shay2nak
dental floss is the best. only takes a few seconds.
i tried fishing line and that was a huge waste of time.
Yeah - actually waxed floss might work even better than fishing line.
Actually removing end plates off my wing right now, and that's a royal PITA - not nearly as easy as getting the nose badge off.
Cheers,
-Darryl
I used an old credit card.
i'm trying to do this and I am FAILING miserably....IT'S EMBARRASSING.
Maybe I have weak floss, but it's not cutting "jack squat".....what type of floss are you guys using?
Good call on the heat gun...gonna leave my car in the sun a bit to warm up that "glue"....
Man...I really need the horsepower this black badge is going to provide damnit!
Just did mine. :up: on the floss. got it 95% of the way cut, then used a flatblade screwdriver to very gently pry it up. Super simple!
I tried the floss so many times, but couldn't get through the double sided tape. So I tried using a zip tie in the same manner, and worked like a charm. Now on to ordering my black emblem! :nanner:
1 - 20 of 31 Posts
